F-body brake up grade? #1171276
02/03/12 06:04 PM
02/03/12 06:04 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
A friend has a 48 Dodge Panel Truck street rod. It has a Volare/Aspen front end in it. He is looking to improve the braking.
Does anyone know if there are bigger rotor and capiler kits out there that will mount on the stock F-body spindles?
Re: F-body brake up grade? [Re: rarefish] #1171277
02/03/12 08:30 PM
02/03/12 08:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The 11.75" rotor with corresponding caliper adapter works great. Cordobas are good donors for both and the adapter is compatible with the F body calipers.
I've run this setup on several A bodies, an M body and a 64 300 I converted to discs. Also on my 38 Plymouth (that was an entire front suspension swap though).
Don't be the exception.
Re: F-body brake up grade? [Re: Supercuda] #1171278
02/03/12 09:47 PM
02/03/12 09:47 PM
X2. Get some aggressive pads & do a bed in procedure
Re: F-body brake up grade? [Re: rarefish] #1171279
02/03/12 10:23 PM
02/03/12 10:23 PM
AndyF Offline
AndyF  Offline
There are a ton of kits that bolt to a stock F body knuckle. Baer has kits that go as large as 15 inch rotors with billet 6 piston calipers.
Re: F-body brake up grade? [Re: AndyF] #1171280
02/04/12 10:00 PM
02/04/12 10:00 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Stange that you mention Baer Brakes. My friend told me that he had called Baer and the person that he talked to said that they did not make any kits for Mopar F-Body cars.
Re: F-body brake up grade? [Re: rarefish] #1171281
02/04/12 10:41 PM
02/04/12 10:41 PM
AndyF Offline
AndyF  Offline
Baer has a bunch of kits that fit F body spindles. T4, 6P, and 6S kits, etc. I'd think that most of their kits would fit any FMJ body car. The only thing that might not fit right out of the box would be the brake hose. You might need a custom brake hose but that isn't a big deal.
Re: F-body brake up grade? [Re: AndyF] #1171282
02/04/12 10:46 PM
02/04/12 10:46 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Thanks for the info. I will be sure to pass it on to him.
Re: F-body brake up grade? [Re: rarefish] #1171283
02/04/12 11:02 PM
02/04/12 11:02 PM
AndyF Offline
AndyF  Offline
If you don't want to go with Baer then give DoctorDiff a call. He has a 14 inch rotor kit that will fit on the F body knuckle. My 13 inch Viper kit will also fit those knuckles. I'm sure that Wilwood has kits also. So there are a ton of kits available for F body knuckles. I covered all of this in my B-body book if you want to see pictures of all the kits.
Re: F-body brake up grade? [Re: AndyF] #1171284
02/05/12 12:20 AM
02/05/12 12:20 AM
New York
rarefish Offline OP
rarefish  Offline OP
New York
I would guess that he will be limited on his rotor diameter due to the fact that his wheels are a 15x7 Torque Thrust.
