Challenger License Plate Bracket #1170729
02/02/12 04:39 PM
02/02/12 04:39 PM
MoreParts Offline OP
I'm being hassled by the Man. I need to get my front plate on. Anyone know if the bracket in the pic is correct for a '70 Challenger?
Also, I don't know where it mounts. My bumper and valance don't have any corresponding holes to mount this thing. Does anyone have a pic or a diagram as to where they go? Where the holes there from the factory or where they dealer installed?
Thanks!
Re: Challenger License Plate Bracket [Re: MoreParts] #1170730
02/02/12 04:45 PM
02/02/12 04:45 PM
NewEngland ( Ma, Ct )
MoparJoeMA Offline
MoparJoeMA  Offline
Looks like the right one. It goes on the Valance in the middle where the bumper is cut out. It mounts direct to the Valance. It hooks over the top and them you have to drill the two lower holes out..
I'll see if i have a pic in my files that shows the holes..
Joe.
Re: Challenger License Plate Bracket [Re: MoreParts] #1170731
02/02/12 04:45 PM
02/02/12 04:45 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Challenger License Plate Bracket [Re: Challenger 1] #1170732
02/02/12 04:48 PM
02/02/12 04:48 PM
I'm glad I asked! I have no holes in that area at all. Is it common not to have the holes in the valance?
Re: Challenger License Plate Bracket [Re: MoreParts] #1170733
02/02/12 04:56 PM
02/02/12 04:56 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Valance interchanges from 70-74 but only 70-71 use that style bracket... So 72 & up valance won't have the holes...
Re: Challenger License Plate Bracket [Re: MoreParts] #1170734
02/02/12 04:59 PM
02/02/12 04:59 PM
Cincinnati, Ohio
Cincinnati, Ohio
Re: Challenger License Plate Bracket [Re: 1_WILD_RT] #1170735
02/02/12 05:00 PM
02/02/12 05:00 PM
I've had the car for over 20 years, but it's possible the front valance has been switched.
Do the holes on the top of the bracket get screwed down or just the two lower ones?
Re: Challenger License Plate Bracket [Re: MoreParts] #1170736
02/02/12 05:56 PM
02/02/12 05:56 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yes it mounts with 4 bolts.
Re: Challenger License Plate Bracket [Re: Challenger 1] #1170737
02/02/12 06:03 PM
02/02/12 06:03 PM
Thanks!
Re: Challenger License Plate Bracket [Re: 1_WILD_RT] #1170738
02/02/12 06:04 PM
02/02/12 06:04 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
IIRC, that liceanse bracket is the same p/n as 1970 Darts??
Re: Challenger License Plate Bracket [Re: autoxcuda] #1170739
02/02/12 06:35 PM
02/02/12 06:35 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
That was a dealer installed piece wasn't it? It came in the trunk from the factory. Not all states require a front plate. I would imagine a lot of them never got installed in those states.
Re: Challenger License Plate Bracket [Re: burdar] #1170740
02/02/12 07:17 PM
02/02/12 07:17 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Is this is one of them? But the 36xxxx part numbers has me questioning it. Doesn't look like it's ever been installed.
Doens't look like it's got a kink in it to fit the center countour of the Challenger valence. (neither does the OP's picture either)
Re: Challenger License Plate Bracket [Re: autoxcuda] #1170741
02/02/12 10:59 PM
02/02/12 10:59 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
That isn't a Challenger bracket..
Re: Challenger License Plate Bracket [Re: MoreParts] #1170742
02/02/12 11:02 PM
02/02/12 11:02 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The top two bolts bolt through the lip that is folded back over at the top of the valance... The bracket hooks over the top of the valance..
Re: Challenger License Plate Bracket [Re: MoreParts] #1170743
02/02/12 11:54 PM
02/02/12 11:54 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
If don't care about being 100% correct, a 73-74 bracket will work. As long as you have the two holes drilled in the bumper on the underside lip at the top of the license plate recess, which you should, you're good to go. You can buy the repop bracket for a reasonable price and bolt it to the bumper. That way, you don't have to do any sheetmetal drilling. I did this on my 73 when I pulled the bumpers in.
Looks good, no drilling...
Re: Challenger License Plate Bracket [Re: 318 Stroker] #1170744
02/03/12 12:05 AM
02/03/12 12:05 AM
That's a great idea, Stroker. That bracket in the first pic is actually mine. But in this case I don't care about originality if it could save me from drilling. As it turns out I'd still have to drill because my bumper only has one hole in the center.
Re: Challenger License Plate Bracket [Re: MoreParts] #1170745
02/03/12 12:14 AM
02/03/12 12:14 AM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Let me know if it works out... The repop bracket has the two outboard holes which you can use to mark the bumper.
Can you drill the bumper without fragging the chrome?
Re: Challenger License Plate Bracket [Re: 318 Stroker] #1170746
02/03/12 12:23 AM
02/03/12 12:23 AM
I don't think I can safely drill the bumper. I'll stick to the valance. Maybe duct tape and bailing wire if I can't work up the nerve.
Re: Challenger License Plate Bracket [Re: MoreParts] #1170747
02/07/12 11:44 AM
02/07/12 11:44 AM
midwest
68427vette Offline
68427vette  Offline
midwest
stick the plate up in the windshield,, or under your seat,, if you get nailed by the man,, throw it up on your dash, i did that with my 01 yellow conv vette, i dont think i'd be drilling anything , jc
