Will these carpets work on a 70 Cuda? #1170350
02/02/12 12:44 AM
02/02/12 12:44 AM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
I am ready to put carpet in my 70 Cuda floor shift automatic. I'm not sure how I ended up with every carpet but the correct one, but I have a 70 Cuda 4-speed carpet, and a 70 Challenger floor shift automatic carpet. Will either of these work? I don't mind trimming something down.
Re: Will these carpets work on a 70 Cuda? [Re: Mike H] #1170351
02/02/12 04:53 AM
02/02/12 04:53 AM
cataclysm80 Offline
cataclysm80  Offline
If you don't want to order another carpet, I think I'd suggest the Challenger carpet because it has the molded shape to match your shifter style. Challenger wheelbase is 2 inches longer, right about the same spot where the carpet overlaps I think, so you might have 2 inches of extra overlap. If you don't mind opening up both sets of carpet, maybe you could use the Challenger front & the Cuda rear and you might have the right stuff.
Tav
