how to wire the starter from 1 post to 2 post
#1170173
02/01/12 06:52 PM
02/01/12 06:52 PM
Posts: 649 Davis, California, USA
MrBelvedere2
Here is my situation. I am putting a 383/727 into my 1956 plymouth. It previously had a 361 in it with a powerflite transmission. The old starter was only 1 terminal up to the solenoid on the fenderwell and worked fine. I now have a mini starter in it with the 383/727 combo. The big wire is still there but it won't crank. I assume it is because I need to wire the usual small wire that comes from the starter as well. What exactly does that wire do and where can I put it. I am just afraid of frying the electrical system if I do it wrong. Thanks for any help.
1965 Plymouth Belvedere II hardtop
Re: how to wire the starter from 1 post to 2 post
[Re: MrBelvedere2]
#1170176
02/01/12 08:15 PM
02/01/12 08:15 PM
Posts: 26,008 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you want to retain the original firewall solenoid and its wiring, just put an 18 ga jumper wire between the large and small terminals on the starter.
[Re: John_Kunkel]
#1170177
02/01/12 09:38 PM
02/01/12 09:38 PM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
the starter won't engage until the solenoid pushes the drive into the ring gear. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: mopar_man]
#1170178
02/01/12 09:41 PM
02/01/12 09:41 PM
MrBelvedere2
thank you john. I did want to keep my original wiring and firewall solenoid. I figured I was going to have to run a seperate wire to the solenoid just wasn't sure which one. jumper wire it is. Thanks!
[Re: mopar_man]
#1170179
02/02/12 02:09 PM
02/02/12 02:09 PM
Posts: 1,613 westerly, ri. usa
440lebaron
westerly, ri. usa
hello, if you jump large term to small starter will stay engaged all the time. large wire should be battery hot.
small wire should go to starter relay (hot with key in crank position)
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 383man]
#1170183
02/27/12 11:52 PM
02/27/12 11:52 PM
MrBelvedere2
Ok here's an update. I did the jumper between the small and big posts on the starter. I went to turn over the engine. The starter did spin, but did not engage the engine. After turning it for a couple seconds, the positive post on the battery started smoking and the positive cable was very warm. Any ideas?
