Horsepower estimate #117003
09/07/08 10:25 PM
09/07/08 10:25 PM
Moncton, New Brunswick
hemidart1 Offline OP
anyone have a ballpark estimate of the HP of a 440(10.5 to 1) with the Indy Sr Top End kit with a 509 cam and a 750 carb?
thanks
Al.
1967 Hemi GTX
1969 Chrysler 300
Re: Horsepower estimate [Re: hemidart1] #117004
09/07/08 10:40 PM
09/07/08 10:40 PM
Well stock you can figure around 390hp before any changes if you compression estimate is accurate. Given the cam and head improvements I would guess somewhere between 425 to 450 to be on the safe side and depending on if there have been any other changes made that you didn't mention. If you figure a max of 450hp you should be fairly close.
Re: Horsepower estimate [Re: hemidart1] #117005
09/07/08 10:42 PM
09/07/08 10:42 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
little better carb 850 and 557 solid 500hp easy
MOPAR OR NO CAR
Re: Horsepower estimate [Re: hemigod426] #117006
09/08/08 07:42 AM
09/08/08 07:42 AM
thanks!
1967 Hemi GTX
1969 Chrysler 300
