Strange Electrical Problem, UPDATED
#116977
09/07/08 10:12 PM
09/07/08 10:12 PM
Posts: 363 Richmond, TX
Sinister68
Richmond, TX
Having a strange problem with the 440 in my Charger. Yesterday I replaced the distributor. The Mallory Unilite ate itself up from the inside out so I replaced it with a trusty Mopar Performance (magnetic trigger) distributor. It cranked and fired fine. However, after shutting it off to prepare for timing the engine with the new distributor, the engine wouldn't fire again. When I crank the engine, it sounds like 1 or 2 cylinders cause the starter to labor severely (like the starter can barely spin the engine). However, the starter does eventually spin the engine. How can the engine run fine one minute and the next minute there seem to be 1 or 2 cylinders that cause interference when the engine is spun over? I can't run the starter too long without the positive and negative battery cables getting hot to the touch (trunk mounted battery). I've reinstalled the negative battery cable by attaching it directly to the frame. I've also replaced the starter and this problem still persists. Any ideas? Hurricane Ike appears to be heading to Houston so I might lose the Charger altogether if I can't drive it out of harms way.
-James
2013 Challenger SRT
1968 Charger R/T
Re: Strange 440 Problem
[Re: Sinister68]
#116978
09/07/08 10:20 PM
09/07/08 10:20 PM
RapidRobert
starter EDIT whoops I reread the post(more slowly this time). not the starter.
[Re: Sinister68]
#116981
09/07/08 10:23 PM
09/07/08 10:23 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
Sounds like the timing it way too high.Move the distributor back towards the firewall a little bit until she starts,then set your timing. Double check your plug wires at the cap.Did you switch the cap along with the distibutor? It may be possible to be of by one plug wire. But I am not there. If you really need to move the car to safe shelter,tow it outa there.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: Sinister68]
#116983
09/07/08 10:32 PM
09/07/08 10:32 PM
You may have a fried module in the distributor causing it act like the timing is too advanced. If that's the case you'll need a different distributor or a replacement module. You may also want to check your ballast resistor to see if it's still good. You should have 12 volts on the switch side and about 9.5 on the coil side if it's the stock ballast resistor. I would bet it's a problem with your distributor advancing the timing too much though.
[Re: Sinister68]
#116984
09/07/08 10:51 PM
09/07/08 10:51 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Sorry, stupid question: How would the distributor cause the engine to labor when spinning?
Because you have a crossfire. You are firing a cylinder way before it get to the top causing the motor to kick back and basicly seem to stop cranking for a split second.
[Re: cyphre666]
#116986
09/08/08 11:07 AM
09/08/08 11:07 AM
Sinister68
Richmond, TX
Thanks for the replies! The distributor cap and rotor are new. I'll start by retarding the timing and then go from there. BTW, will this problem cause any engine damage I should be aware of?
-James
2013 Challenger SRT
1968 Charger R/T
[Re: Sinister68]
#116987
09/08/08 11:55 AM
09/08/08 11:55 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
TIming too far advanced means the mixture can fire when the piston is in the wrong part of it's travel, and the engine wont turn. Grab the dist and turn it clockwise about 1/4. It should start for you. Dont forget to plug the vacuum can line to the carb.
UPDATE:
[Re: IMGTX]
#116989
09/09/08 10:17 PM
09/09/08 10:17 PM
Sinister68
Richmond, TX
Update: I checked every inch of the positive battery cable from the battery in the trunk to the starter and the cable looks fine. I pulled all but 2 of the spark plugs and disconnected the distributor. The engine spins fine except for (presumably) the 2 plugs that were still left in the engine. During those two cylinders, the starter labors. After cranking, the positive battery cable (and to a lesser extent) the negative battery cable, were hot to the touch. Any ideas? The trunk mounted battery setup has been working for nearly 2 years without problems. Why would I have electrical problems now?
-James
2013 Challenger SRT
1968 Charger R/T
Re: UPDATE:
[Re: Sinister68]
#116991
09/09/08 11:23 PM
09/09/08 11:23 PM
RapidRobert
When a starter cranks slower it draws MORE current which heats up the cables, could the batt have dropped a cell & be causing what I threw out there?. Ordinarily from your description of the symptoms I would think a bad connection in the big cable system but you've checked them all.
Re: UPDATE:
[Re: RapidRobert]
#116992
09/09/08 11:43 PM
09/09/08 11:43 PM
Sinister68
Richmond, TX
I've reattached the negative battery cable. It was only attached to the trunk floor, but now I've added a longer bolt which makes contact at the trunk floor and the bottom of the frame rail. I replaced the light weight MP starter with a brand new light weight starter for an '98 Ram (5.9L). What are the odds of having 2 bad starters? The battery is an Optima red top and is only 3 weeks old. Tomorrow I'll try swapping out the battery in my '05 Ram with the Charger's battery and see what happens. Both batteries are the same brand/type. I don't know what else could be causing this. I really appreciate everyone's responses!
-James
2013 Challenger SRT
1968 Charger R/T
Re: UPDATE:
[Re: RapidRobert]
#116993
09/10/08 08:24 AM
09/10/08 08:24 AM
starter is high current draw. battery in trunk means long cable. long cable means higher resistance. higher resistance means more heat.
Make sure- ABSOLUTELY SURE- that every connection is SHINEY and CLEAN. batt terminals, starter terminals, ground to the block. ground to the frame. I WANT SHINEY METAL THERE on the the face, on the threads of the bolts, on the face of the nuts that hold them down. MAKE SURE you have a HEALTHY ground wire from the battery to the frame if you are not running a ground wire from the battery to the block. it is a circuit. both sides of the ciurcuit need to be clean and low resistance
Re: UPDATE:
#116994
09/10/08 12:39 PM
09/10/08 12:39 PM
I may have missed it in some of the above posts:
WHAT SIZE is the pos/ neg cables?
DO YOU have a BIG jumper from the block to the frame/ body?
When you trunk mount a battery in a Mopar, because the bodies are welded (unibody) you don't need to worry too much about "the frame", but make sure if the battery is grounded to the unibody, then the engine block is, also, IE don't hook to a rusty memeber like the K frame, which bolts on.
