1973 roadrunner big block oil pan #1169712
02/01/12 12:19 AM
02/01/12 12:19 AM
north carolina usa
beeson44 Offline OP
beeson44  Offline OP
north carolina usa
I am putting a lowdeck motor in my 318 roadrunner,What pans fit the 1973 k frame I wanted a street hemi pan but not sure it will fit.Has anyone been down this road before? thanks
Re: 1973 roadrunner big block oil pan [Re: beeson44] #1169713
02/01/12 12:27 PM
02/01/12 12:27 PM
Shoreline, Washington
72roadrunnergtx Offline
That should be the “971” pan for that application.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: 1973 roadrunner big block oil pan [Re: 72roadrunnergtx] #1169714
02/03/12 08:14 PM
02/03/12 08:14 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Correct...Here's all the info and part numbers for the application.. Best of MOPARTS/ tech archives
Re: 1973 roadrunner big block oil pan [Re: 72roadrunnergtx] #1169715
02/03/12 09:05 PM
02/03/12 09:05 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
That is the right pan. I have a 971 pan that was a brand new pan that was painted and clearanced for a 1/2 inch pick-up in the baffles,ran on the Dyno then wouldn't clear the K-member..So an aftermarket pan was then used. Pm me if interested I can send pics....
