Milodon Gear Drive/ Early Hemi #1169546
01/31/12 08:19 PM
01/31/12 08:19 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
Here is the Milodon gear drive #13600 that is listed for small block Mopar and Chrysler 331 354 and 392 hemi. I am thinking that someone in R&D was concentrating on the mounting holes, and not the location of the early hemi oil galleys.
My question is would you use a cup type plug in each hole, or would you tap them for threaded plugs?
Re: Milodon Gear Drive/ Early Hemi [Re: TrWaters] #1169547
01/31/12 08:22 PM
01/31/12 08:22 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
1/3 of each hole is left open.
Re: Milodon Gear Drive/ Early Hemi [Re: TrWaters] #1169548
02/01/12 12:29 AM
02/01/12 12:29 AM
Cab_Burge Online work
Cab_Burge  Online Work
I would probally tap them, but look inside those holes to make sure there are no cross block oil passages in them first, go from there
Re: Milodon Gear Drive/ Early Hemi [Re: TrWaters] #1169549
02/01/12 01:40 AM
02/01/12 01:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I tap those holes for plugs
Re: Milodon Gear Drive/ Early Hemi [Re: MR_P_BODY] #1169550
02/01/12 12:26 PM
02/01/12 12:26 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
Thanks. And yes, there is an oil passage about 3/8" in on each side.
Re: Milodon Gear Drive/ Early Hemi [Re: TrWaters] #1169551
02/01/12 02:50 PM
02/01/12 02:50 PM
Don't block those passages See if you can get some shollw cup press in plugs(welsh plugs) that size and make sure they don't block those passages
