mag heads(rocker question) #1169425
01/31/12 04:01 PM
01/31/12 04:01 PM
Dayton, OH
1980volare Offline OP
My man card has just been revoked.
Dayton, OH
La 318 with magnum heads, can i use a 1.7 roller rocker WITHOUT machining the head for clearance?
Has anyone been running 1.7 rockers on there La/Magnum headed engine?
Re: mag heads(rocker question) [Re: 1980volare] #1169426
02/02/12 01:10 PM
02/02/12 01:10 PM
dogdays Offline
dogdays  Offline
Guess time: I guess you'll have to open up the pushrod hole on the inside, a higher ratio rocker moves the pushrod towards the center of the cylinder.
Whose 1.7s are you running? I have a set of ford smallblock 1.7s and if the ford 1.6s work on a Mag head they might work also. Anyone try this?
R.
Re: mag heads(rocker question) [Re: 1980volare] #1169427
02/03/12 11:45 PM
02/03/12 11:45 PM
Arlington Heights, IL
Ovalracer68 Offline
Ovalracer68  Offline
running la 360 with magnum rt heads
i have 1.6 roller rockers and they required a lot of drilling / grinding for pushrod clearance
