Re: Need some help for a 426 Hemi Oil system [Re: B G Racing] #1169166
03/09/12 12:13 PM
03/09/12 12:13 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
there are three variables that determine the volume of oil flowing through the engine. pressure, viscosity and engine clearances. an increase in pressure or clearances will increase flow, a decrease in viscosity will increase flow. this is of course assuming the pump has not reached it's capacity.
Re: Need some help for a 426 Hemi Oil system [Re: jamesc] #1169167
03/09/12 02:04 PM
03/09/12 02:04 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
We have used a 6" deep aluminum pan, 8 Qts oil, stock volume oil pump, single line system for over 10 years. We have run a variety of upper end oiling and rockers- Stock, Mopar/DLI, Stage V, Barton, Jesel; full time rocker oiling w restrictors, oil thru the pushrods, Barton spray bar. Hundreds of runs at 8600+ RPM, no problems.
Be a Rebel- Break the Laws of Physics!
Re: Need some help for a 426 Hemi Oil system [Re: mbogina] #1169168
03/11/12 10:57 AM
03/11/12 10:57 AM
Bethel CT
monte442 Offline
monte442  Offline
Bethel CT
To the OP,I have a 440 Source billet oil pump cover for the external pick up if you are interested. I also have some new Manton push rods with .040 restrictors in them. PM me if you are interested.
