Removing reservoir on Mopar alum. Master Cylinder... #1168771
01/30/12 05:32 PM
01/30/12 05:32 PM
The Netherlands
BigBlockMopar Offline OP
The Netherlands
Is it possible to do without damage?
I'm looking into turning the MC into a remote reservoir-version.
I tried applying some moderate amount of force at seperating the reservoir from the cylinder, but didn't want to fubar anything.
So... anybody done this before with succes?
What's the 'catch'...?
Re: Removing reservoir on Mopar alum. Master Cylinder... [Re: BigBlockMopar] #1168772
01/30/12 05:43 PM
01/30/12 05:43 PM
They do take a significant amt of effort. Just pull straight up w a slight amt of side to side wiggle. They have to be tight or if there was a fluid loss/injury accident it'd be lawsuit city for Ma
Re: Removing reservoir on Mopar alum. Master Cylinder... [Re: RapidRobert] #1168773
01/30/12 06:43 PM
01/30/12 06:43 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
There's a spot that looks like it's made to use a prybar of some sort. Use a BIG screwdriver.
You think getting it apart is tough ... try putting it back together!
Re: Removing reservoir on Mopar alum. Master Cylinder... [Re: RapidRobert] #1168774
01/30/12 06:54 PM
01/30/12 06:54 PM
The Netherlands
The Netherlands
I'll give it a go again tomorrow.
Anyone know of a nice exploded view of such a MC?
Might make things a little easier if I know what exactly is holding the reservoir and by how much material.
I think it's probably something similar as the tough pushrod-grommet in stock MC's, only larger.
Re: Removing reservoir on Mopar alum. Master Cylinder... [Re: BigBlockMopar] #1168775
01/30/12 06:58 PM
01/30/12 06:58 PM
Not near that bad
Re: Removing reservoir on Mopar alum. Master Cylinder... [Re: BigBlockMopar] #1168776
01/30/12 07:09 PM
01/30/12 07:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Like what was said, it'll pop straight up and come off with no tools needed, just strong arms.
I have replaced a few master cylinders where you reused the plastic reservoir. It just keeps the master cyl covered in fluid. If it came off you would still have brakes for a few pumps. lol
Re: Removing reservoir on Mopar alum. Master Cylinder... [Re: Challenger 1] #1168777
01/30/12 07:38 PM
01/30/12 07:38 PM
The Netherlands
The Netherlands
If my plan works out I don't intend to put it back again into the cylinder-body.
I hope to be able to mount some kind of similar fitting in the housing where I can connect some short tubing to so the reservoir can be replaced in a more accessible position.
