Re: 727 leak ??
[Re: cold85]
#116878
09/07/08 07:58 PM
09/07/08 07:58 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The rod is the pivot pin for the rear band links, it has an O ring seal that often shrinks and leaks. As you have seen there is a tab on the tailhousing that prevents the rod from being pulled out enough to replace the O ring.
The down-and-dirty fix is to clean the area around the rod end thoroughly with brake kleen and cover the end of the rod with RTV. The fluid level in the trans must be drained below the level of the rod or the leaking fluid will prevent the RTV from properly adhering.
Goop it up and let it sit overnight before refilling with fluid.
