neutral safety switch?back up lights not working #116867
09/07/08 06:56 PM
09/07/08 06:56 PM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
I have tried two new switches, the car starts fine in park & neutral. the back up lights will not come on with everything hooked up. It is getting power from the one side but is not closing the loop and sending power back to the power block on the firewall through the 2nd wire. if i jump the plug end @ the switch end the brake lights come on.if i plug the switch in with it not screwed into the trans the back up lights come on. I looked in the trans with the switch out and it seems to be in the correct position, What is my problem?
Re: neutral safety switch?back up lights not working [Re: satgtx] #116868
09/07/08 07:15 PM
09/07/08 07:15 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
There was this similar post about a year ago:
https://board.moparts.org/ubbthreads/show...rue#Post3497079
You can "test" the switch to see if the "reverse" portion of the Neutral-Safety/Backup Switch is functional.
Beyond that, the wiring (and you have checked the fuse too) and the light-bulbs/sockets (no corrosion, filament intact, etc) and beyond that it could be the contact-arm inside the transmission.
Process of elimination. Funny how sometimes it turns out to be something like corrosion, etc.
Good Luck.
Re: neutral safety switch?back up lights not working [Re: D_C] #116869
09/07/08 07:21 PM
09/07/08 07:21 PM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
the back up lights work fine when i jump the power side with the return side of the plug. they also work when i have the switch plugged up but out of the trans. so it has something to do with when the switch is installed. like something is out of line, i almost thought i screwed the switch in to tight but that did not seem to work either.
Re: neutral safety switch?back up lights not working [Re: D_C] #116870
09/07/08 07:23 PM
09/07/08 07:23 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
is it me or did u write BRAKE lights come on when u jump it?
Re: neutral safety switch?back up lights not working [Re: AARCONV] #116871
09/07/08 07:29 PM
09/07/08 07:29 PM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
oops, i meant back up lights.
Re: neutral safety switch?back up lights not working [Re: satgtx] #116872
09/07/08 07:50 PM
09/07/08 07:50 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's the scoup...The aftermarket switches come with the center pin too long...You'll need to file the center pin so when it drops into the rooster comb rev. detent the switch plunger bottoms out and the your rev. lights will come on...I've had to file every aftermarket switch I've installed the past few years to get the rev. lights to work...This really should go in the tech archives seeing how many times a year this new aftermarket switch problem comes up....
Re: neutral safety switch?back up lights not working [Re: satgtx] #116873
09/07/08 07:51 PM
09/07/08 07:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There is a metal pin in the center of the plastic bushing in the switch, in order for the BU light circuit in the switch to close, the pin must be able to extend into the "divot" in the plastic shoe inside the transmission (see pic below).
If there is something plugging the divot or if the divot is not centered in the hole in Reverse the BU portion of the switch can't function.
Re: neutral safety switch?back up lights not working [Re: John_Kunkel] #116874
09/07/08 08:08 PM
09/07/08 08:08 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Be real careful screwing that switch in thier its possible to break that plastic piecs off just past the metal and the your backup lights come on in all forward gears. Ask me how I know
Re: neutral safety switch?back up lights not working [Re: Cudajon] #116875
09/10/08 07:32 PM
09/10/08 07:32 PM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
Thanks all, yes the filing of the tit on the end of the switch worked. I now have back up lights. This needs to go in the Tech tips.
Re: neutral safety switch?back up lights not working [Re: satgtx] #116876
09/10/08 10:34 PM
09/10/08 10:34 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I put a NOS switch in my car. The cheap aftermarket one lasted about six months for me. Mike
