Re: soda blasting a trans
[Re: burdar]
#1168534
01/30/12 02:11 PM
01/30/12 02:11 PM
Posts: 489 NE
bigtail
NE
Don't know if this will help you, but on Cope racing Transmission site, they say they glass bead all cases inside and out. I don't know what kind of finish it will give you. Might have to experiment a bit. I don't know how you would seal it. Blasting stuff seems to get everywhere.
This page is made up completely of recycled electrons.
[Re: burdar]
#1168537
01/30/12 02:30 PM
01/30/12 02:30 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Soda blasting will inpart a shine to the case as the soda is so fine, glass bead really opens the surface, and will inpart a dull finish, that will soon oxidize, find someone that can blast with walnut shells or cherry pits (really) it will inpart a more natural finish, you can easily block the side tubes with npt plugs, and tailshaft slip in plugs are cheap, from Summit, Jegs, etc, keep or throw a converter in it to prevent anything getting past the seal,make a strap/bolted across the converter to hold it in, and either remove and plug the tube hole, or duct tape the handle in the tube, plug the vent with a npt plug,...then you should be good to go, have them stand it on the bell only when blasting
[Re: burdar]
#1168538
01/30/12 02:46 PM
01/30/12 02:46 PM
Posts: 21,485 It's a dry heat
gtx6970
It's a dry heat
My if your going to blast it 'with anything'. dis-assemble it to a bare case before doing so.
[Re: burdar]
#1168539
01/30/12 06:35 PM
01/30/12 06:35 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Dry ice is the only blasting media I would use on an assembled transmission.....protect the seals.
[Re: gtx6970]
#1168541
01/30/12 07:43 PM
01/30/12 07:43 PM
Posts: 2,177 ill
dennismopar73
ill
My
No way would I blast a trans assembled! to me wouldn't do one any ways, get out some alum tank shine?cleaner be happy, find nice color you like paint the outside inside would be a cleaner and a wash be happy!
[Re: Seventythree]
#1168542
01/30/12 07:57 PM
01/30/12 07:57 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Regardless of the blast media used, any blast media (including dry ice) will dislodge the paint and risk contaminating the orfices on the trans. I have seen dry ice blasting being done, and it makes a heck of a wet mess of the surrounding area, think wet paint.
huh?
dry ice is, uh, dry. it's CO2. no water. if you use dry ice, then the moisture came from somewhere else.
GE uses dry ice blasters to clean their equipment at the light bulb plant in Bucyrus. but there is no moisture anywhere. they're cleaning oil and grease, light bulb coating dust, etc. off the equipment. nothing gets wet.
but, yea, even using dry ice to blast a trans...not only is it going to be expensive (where you gonna buy dry ice to blast with, or the eqipment to keep the dry ice from melting before you can use it?) but it will also leave paint chips that could get into the trans.
if it was mine, and I was trying to get an "as cast" appearance, I'd try oven cleaner sprayed lightly, scrubbed with a brush and rinsed away quickly. do not let it sit, as it WILL eat into the aluminum.
but I gotta ask, why do you want a bare, 'as cast' look? it's going to tarnish and oxidize rather quickly. is there a paint you can use to just re-paint the trans?
**Photobucket sucks**
