Re: Weird Cam Bolt Washer [Re: 62maxwgn] #1168496
02/01/12 01:28 PM
02/01/12 01:28 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
The hardware stores around here have hardened bolts and washers. i.e. grade 5 & 8.
I have mechanical Aptitude.
I can screw up anything.
Re: Weird Cam Bolt Washer [Re: kidmopar] #1168497
02/01/12 01:28 PM
02/01/12 01:28 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
That is the correct washer for the small block stuff. Its got that concave shape to let the cam come through the fuel pump ecentric on small block set ups. Wrong for a big block, and accually crappy on the small blocks also. I use a billet aluminum washer thats cut to clear the cam.
Kasey
