Broke the transmission cooler fitting. FIXED #1168247
01/30/12 12:27 AM
01/30/12 12:27 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I actually got off my duff and worked on the hot rod today. The list of accomplishments is short. They include :
Swapping the trans pan (made a mess).
Changing the fuel sending unit seal.
Installing the valve covers.
Removing the old cable throttle linkage.
and...
wait for it...
I broke the front cooler line fitting inside the transmission.
While removing the kick down linkage, I found the front line was loose. Tightening the fitting didn't work. It was stripped. When I tried to remove it, the socket wanted to slip off the fitting. I put an extension on the socket so I could hold it at the correct angle and tried again. My reward was having the fitting snap off flush with the transmission case.
If I recall correctly, these are a tapered pipe thread. I do not want to remove the other one for fear of breaking it too. I have a 518 in the garage but don't know if they're the same size.
This is a brass fitting in an aluminum case. If I'm not careful, I'll end up doing really ugly things and the transmission case could be damaged.
I have extractors but don't know how well they're going to work on this.
If I have to drill, can I drop the pan and access this thing or will I have to disassemble the transmission to get the swarf out?
What size thread are the fittings? I've got a variety of SAE, NPT, and even metric taps.
- Stu Harmon
Re: Broke the transmission cooler fitting. Not happy. [Re: feets] #1168248
01/30/12 12:30 AM
01/30/12 12:30 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You'll have to pull the Valvebody if you drill it , it's 1/8 npt . An easyout should get it out.
Re: Broke the transmission cooler fitting. Not happy. [Re: JohnRR] #1168249
01/30/12 12:47 AM
01/30/12 12:47 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
518 fittings are bigger.
Re: Broke the transmission cooler fitting. Not happy. [Re: stumpy] #1168250
01/30/12 12:48 AM
01/30/12 12:48 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I remember the 518 cooler lines being larger but I couldn't remember if the holes were larger too.
- Stu Harmon
Re: Broke the transmission cooler fitting. Not happy. [Re: feets] #1168251
01/30/12 12:53 AM
01/30/12 12:53 AM
Sorry for your bad luck Feets & OT this reminded me of a Q if you could tap to the next size & run 3/8 lines for more cooler flow using a 3/8 cooler of course
Re: Broke the transmission cooler fitting. Not happy. [Re: feets] #1168252
01/30/12 01:03 AM
01/30/12 01:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have 518 fittings , I'll check them , but I think the holes in the case are the same size .
Re: Broke the transmission cooler fitting. Not happy. [Re: JohnRR] #1168253
01/30/12 01:05 AM
01/30/12 01:05 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I have a 518 sitting in my garage. It was going to go into the hot rod but now it's marked for the Imperial.
If I [Edited by Moparts - Family Friendly Site - Keep it clean] up the case on the hot rod maybe I'll swap the 518 in the Imp now and put it's transmission in the hot rod.
- Stu Harmon
Re: Broke the transmission cooler fitting. Not happy. [Re: feets] #1168254
01/30/12 01:15 AM
01/30/12 01:15 AM
Amherst,NY
challengermike Offline
Amherst,NY
They come out real easy with an extractor.I like the ones that you turn in counter clock wise and they spin right out.I think the 518 fittings will be for 3/8 line not 5/16. Any local trans shop should have the correct ones..Just remember not to tighten the new rear fitting to tight into the case,you can crack the case.
Re: Broke the transmission cooler fitting. Not happy. [Re: stumpy] #1168255
01/30/12 01:23 AM
01/30/12 01:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
this is correct , 518 cooler lines , well actually the lines I have are for my 47"RE , look to be 1/4 npt .
And yes the 518 use bigger cooler lines .
Re: Broke the transmission cooler fitting. Not happy. [Re: JohnRR] #1168256
01/30/12 09:17 AM
01/30/12 09:17 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
it will come out pretty easily with an easy out,,,at least I've never had one that didn't .
most ( but not all ) of the later OD trans use a larger cooler fitting and are not interchangeable without drilling and retaping the case
if you want one to replace the broken one you have now, send me your address I have them here
Re: Broke the transmission cooler fitting. Not happy. [Re: gtx6970] #1168257
01/30/12 02:46 PM
01/30/12 02:46 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Thought they were all 1/8" pipe fittings in the case.
Re: Broke the transmission cooler fitting. Not happy. [Re: gtx6970] #1168258
01/30/12 02:54 PM
01/30/12 02:54 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I do appreciate the offer.
There is a local hardware store that is good at stocking odd parts like that. When I pull the pieces out I'll try to match 'em up there first. The place is close to work and I hit it during lunch.
- Stu Harmon
Re: Broke the transmission cooler fitting. Not happy. [Re: feets] #1168259
01/30/12 03:09 PM
01/30/12 03:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I haven't been able to find that specific fitting even at an autoparts store .
Re: Broke the transmission cooler fitting. Not happy. [Re: buildanother] #1168260
01/30/12 03:10 PM
01/30/12 03:10 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
meaning early 727/904 and the 518 ???
Re: Broke the transmission cooler fitting. Not happy. [Re: feets] #1168261
01/30/12 03:15 PM
01/30/12 03:15 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes that fitting is brass and should be easy to get out as long as you can get to it.
The fitting is available at most auto parts store. It'll be male 1/8" pipe thread X 1/4 or 5/16" inverted flare fitting from the factory. Edlemann or Dorman will make the fitting.
Re: Broke the transmission cooler fitting. Not happy. [Re: Challenger 1] #1168262
01/30/12 03:26 PM
01/30/12 03:26 PM
Cincinnati, Ohio
Cincinnati, Ohio
I have them in stock if you need them, would love to send you if you need.
Re: Broke the transmission cooler fitting. Not happy. [Re: Challenger 1] #1168263
01/30/12 04:55 PM
01/30/12 04:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I've only seen them for the standard off the shelf line to screw into and not the way they are from the factory , good to know since I have a limited supply of transmissions to rob them from.
Do you have the part number ?
Re: Broke the transmission cooler fitting. Not happy. [Re: buildanother] #1168264
01/30/12 05:38 PM
01/30/12 05:38 PM
I did too till I stumbled across one (brass) that was larger. No sure if it was OE or not but if those 2 enter/exit points just inside the case itself ain't restricted to less than the fitting ID I'd think the larger ones w 3/8" lines/cooler would give more flow
Re: Broke the transmission cooler fitting. Not happy. [Re: JohnRR] #1168265
01/30/12 06:28 PM
01/30/12 06:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 727 fitting is Edelman #148520, 1/8"-27 NPT X 5/16" flare.
http://www.oreillyauto.com/site/c/detail...5&ppt=C0248
Re: Broke the transmission cooler fitting. Not happy. [Re: feets] #1168266
01/30/12 06:35 PM
01/30/12 06:35 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Find a short Torx bit that is the size that can be driven inside the broken piece(interference fit). Usually the tapping required to get the torx bit to bite will also serve to loosen up the broken pc. Just carefully back it out. Works great..
MB
