Re: Help Identify These Parts...
[Re: lahatte]
#1168143
01/30/12 01:39 AM
01/30/12 01:39 AM
Posts: 175 Red Lion, PA USA
scamper340
Red Lion, PA USA
Not sure what you are working on, or if they are misc. parts you have there but I'll give it a try, but I'm going off of what I've seen on A-bodies. I believe the sheet metal nut(bottom right)is a retainer for a remote mirror knob. The "ring with the 4 tabs" looks like a window regulator roller retainer. To the left of that looks like rubber glove box door bumpers. Flange nut, have a couple in my parts bins, but I can't think of where they go right now. And you're right they aren't like a regular flange nut, the flanged area is indeed wedge shaped. Same with those 3 funky looking sheet metal nuts to left. I know I've seen them before, but can't place them right now. To the left of the flange nut at the bottom, looks like the retainer for the pin that holds the e-brake handle to the dash (A-body). If you think that's what it might be, I can get you a picture to show where it goes. The roll pins might also be for an e-brake handle as well, as there are 2. One to attach the plastic handle to the hollow rod and one in the other end of the rod that catches the pivot spring. That U shaped thing in the top right, is that a sheet metal clip? Again, I know I've seen it before, and now it's going to bug me until I figure it out. That's the best I can do for now, and I might be way off. Maybe someone else can throw in here.
[Re: scamper340]
#1168144
01/30/12 02:19 AM
01/30/12 02:19 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Retaining clip for the vacuum hose harness on the A/C control maybe?
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: lahatte]
#1168145
01/30/12 02:22 AM
01/30/12 02:22 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
It would help if you could say what car you think they belong to. My expertise is limited to just one restoration, a 69 Barracuda 340-S.
1. Two rolled pins at upper left: 2 pcs 3/16" dia x 1" L are used in the exterior door handles return assemblies. One pc same size connects parking brake tube to lever. Another pc 3/16" dia x 13/16" L connects parking brake handle to tube.
2. Rubber bumpers: Looks like the 2 bumpers in the dash panel that the glove compartment door closes on. These fit a 1/4" hole.
3. Retainer with 4 tabs in the ID: Retains quarter window plastic rollers.
4. Stamped nut in lower R corner: If 3/4"-10 threads and 1 1/8" across flats, could be the manual transmission reverse indicator light retainer in the instrument panel. Or some similar I.P. app due to good condition.
5. Rusty nut, lower center: If this is a one-piece locking hex flange nut, and if 3/8-16 thd, could be for muffler clamp. If 5/16-18 thd, could be for park brake cable adjuster rod, or wiper motor to firewall, or manual transmission floor shift lever.
6. Spring nut, push type, lower L center w 8 ID slits: If for 3/16" stud and 0.44" O.D., likely retains one of the control cable ends that attaches to a lever, switch, or door in the heater or A/C box.
