"Copper" colored connecting rods in an engine (318)???
#1167941
01/29/12 08:23 PM
01/29/12 08:23 PM
Posts: 697 Central IL
70Sbird
Central IL
Hey all quick question here, I stripped down a 1977 318 for a quickie overhaul and found it has been gone through before. It has .030 over flat top pistons and the rods and mains are .010 under as well. One thing I did notice was that two of the connecting rods are "Copper" colored. It doesnt appear to be paint, but some other coating or cleaning process? I havent see anything like that before. anyone know what is going on here. Thanks Scott
Re: "Copper" colored connecting rods in an engine (318)???
[Re: 70Sbird]
#1167942
01/29/12 08:41 PM
01/29/12 08:41 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
Not unusual to see that in motors straight from Mopar,Especailly SB Probally a coating put on them to bring them into spec. on the rod bearing or wrist pin ends Or both ends
[Re: 70Sbird]
#1167943
01/29/12 09:04 PM
01/29/12 09:04 PM
RapidRobert
I have a bunch of the copper ones, BB I think. Not sure of the purpose either
[Re: Cab_Burge]
#1167944
01/29/12 09:04 PM
01/29/12 09:04 PM
Posts: 15,487 Florida
scratchnfotraction
IIRC those rods were factory check and had a dye put on them,they did every so many comeing down the line. sorta like the stock pink rods chebby guys drool over,they will hunt up 8 pink rods,suposed to be the strongest of the stock rods and passed inspection. I have changed colors on metal by soaking it in carb cleaner..but never got a copper color. but this is all hear say from my machine shop guy
[Re: 70Sbird]
#1167947
01/30/12 12:04 AM
01/30/12 12:04 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I had a 318 that was original to the car and had 3 copper clad rods in it.
[Re: 70Sbird]
#1167948
01/30/12 12:34 AM
01/30/12 12:34 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Thanks everyone, So Rick, I'm assuming that if the plating is to bring the rod back into spec, is this likely then a Mopar Remanufactured engine?
No , NOTHING is wasted , they fixed everything for use.
