Clean a aluminum intake with no bead blasting.! #1167815
01/29/12 04:34 PM
01/29/12 04:34 PM
Maryville tn
67coronetman Offline OP
Maryville tn
I have a mopar M-1 intake that i just port matched & was wondering what some of you used out here to clean it & make it look nice again.
I really don't ant to bead blast it if someone has used a product that really works good.
Old car are me......
Re: Clean a aluminum intake with no bead blasting.! [Re: 67coronetman] #1167816
01/29/12 04:43 PM
01/29/12 04:43 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
I used Simple Green barbecue cleaner and a nylon cup brush on my drill. Simple Green and a high-pressure rinse really gets a lot of stuff off with not a whole lot of effort.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Clean a aluminum intake with no bead blasting.! [Re: 67coronetman] #1167817
01/29/12 06:02 PM
01/29/12 06:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I used Mothers mag wheel cleaner , the etching type , spray it on , let it sit for about 20mins then hose it off , repeat as needed .
Re: Clean a aluminum intake with no bead blasting.! [Re: JohnRR] #1167818
01/29/12 06:07 PM
01/29/12 06:07 PM
Up North eh'
Stroked_Hemi Offline
Up North eh'
CLR can clean it too, if cheaper than the wheel cleaners out there.
Re: Clean a aluminum intake with no bead blasting.! [Re: JohnRR] #1167819
01/29/12 06:08 PM
01/29/12 06:08 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
I used oven cleaner. Just dont leave it on to long. You can always apply a second, third or fourth coat, just rinse and repeat. That with a stiff nylon brush and it came out nice. Went to bolt it on and forgot about the end seal pins. Crack. 3 hours wasted.
Re: Clean a aluminum intake with no bead blasting.! [Re: 67coronetman] #1167820
01/29/12 08:45 PM
01/29/12 08:45 PM
Cab_Burge Online work
Cab_Burge  Online Work
Cast aluimunm spray on wheel cleaner works great also
Re: Clean a aluminum intake with no bead blasting.! [Re: Cab_Burge] #1167821
01/29/12 10:01 PM
01/29/12 10:01 PM
Earth
tubedriver Offline
tubedriver  Offline
Earth
Agreed! CLR, oven cleaner, SimpleGreen straight, bare aluminum mag cleaner(hydroFluoric acid)(maybe not available anymore))...any of these work great on bare aluminum....be careful with these if still installed on your engine, will affect other materials. Still will not be as effective as bead blasting.
Re: Clean a aluminum intake with no bead blasting.! [Re: tubedriver] #1167822
01/29/12 10:31 PM
01/29/12 10:31 PM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
Eagle One mag wheel cleaner if you can still get it.
Re: Clean a aluminum intake with no bead blasting.! [Re: rallye73] #1167823
01/30/12 12:38 AM
01/30/12 12:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This was what I used , bought it within the last 6 months at Advanced auto .
Re: Clean a aluminum intake with no bead blasting.! [Re: 67coronetman] #1167824
01/30/12 12:48 AM
01/30/12 12:48 AM
Might be too picky but I'd tape up the ports/flange if glassbeading to keep the beads from possible embedding in inside crevices then heat releasing them later on
Re: Clean a aluminum intake with no bead blasting.! [Re: RapidRobert] #1167825
01/31/12 12:53 PM
01/31/12 12:53 PM
dogdays Offline
dogdays  Offline
Bead blasting ruins the surface and if it is a restorer part ruins the value. The open surface now holds dirt and oil. I have used bead blasting and high temp clear to give a different look but once you open that surface up it's never the same.
R.
Re: Clean a aluminum intake with no bead blasting.! [Re: JohnRR] #1167826
01/31/12 12:58 PM
01/31/12 12:58 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I bought some yesterday morning....for a few manifolds I got from the swap meet.
Not as strong as it used to be from ages ago (but what is here in CA anymore) but still has abit of bite to it and cleaned them ok.
Re: Clean a aluminum intake with no bead blasting.! [Re: dogdays] #1167827
01/31/12 12:58 PM
01/31/12 12:58 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Easiest and most effective thing by far is to clean it up as good as you can, hot tank it if it has 20 coats of paint on it then hit it w/ something like this, then clear coat it. It will look good for a long time and it wont "soak" up oil and grease like natural aluminum.
Coming soon!!!!
Re: Clean a aluminum intake with no bead blasting.! [Re: Mr.Yuck] #1167828
01/31/12 01:00 PM
01/31/12 01:00 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
this is the outcome....
Re: Clean a aluminum intake with no bead blasting.! [Re: Mr.Yuck] #1167829
02/01/12 04:43 PM
02/01/12 04:43 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
How about this intake? was pretty dirty looked like was left in a barn for years
i took it to a monument place let them blast it
i had all ports duct taped up nice
brung home took air hose to it then painted it with some metalic gray/silver the last coat i held back bout a foot and half to give a over spray effect it looks like i took it stright out of the box
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Clean a aluminum intake with no bead blasting.! [Re: toplescuda] #1167830
02/01/12 04:58 PM
02/01/12 04:58 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Differnt intake i did same way
1971 charger
Re: Clean a aluminum intake with no bead blasting.! [Re: toplescuda] #1167831
02/01/12 11:44 PM
02/01/12 11:44 PM
Washington
69440 Offline
69440  Offline
Washington
Ever thought about taking it to your local machine shop and having them soak it over night in their cold tank? Works wonders and won't harm the aluminum.
Re: Clean a aluminum intake with no bead blasting.! [Re: 69440] #1167832
02/02/12 08:26 AM
02/02/12 08:26 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I use a weak Muratic acid solution and then rinse with water. I've tryed using clear acrylic enamel to seal them afterwards but have found that it tends to yellow out in time. Dave
