440-1 heads? #1167709
01/29/12 01:31 PM
01/29/12 01:31 PM
ill
dennismopar73 Offline OP
ill
How much room is needed between the firewall and the 440-1 heads compaired to say stock, or rpms??
This firewall has been moved back, and is smooth
Thanks guys
Re: 440-1 heads? [Re: dennismopar73] #1167710
01/29/12 02:17 PM
01/29/12 02:17 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I'd say 0.
Re: 440-1 heads? [Re: dennismopar73] #1167711
01/29/12 03:02 PM
01/29/12 03:02 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
a 440-1 has the same outer dimensions front to back as a stock iron head.
8.30's @3400 lbs
Re: 440-1 heads? [Re: Mike Swann] #1167712
01/29/12 03:12 PM
01/29/12 03:12 PM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
You will need room for the external oil lines.
Re: 440-1 heads? [Re: Moparpoor] #1167713
01/29/12 03:28 PM
01/29/12 03:28 PM
Not much, if any
Re: 440-1 heads? [Re: Cab_Burge] #1167714
01/29/12 03:40 PM
01/29/12 03:40 PM
Western Kentucky
Muscles Offline
Muscles  Offline
Western Kentucky
Not much, if any
No extra room is needed for the oil lines.
Re: 440-1 heads? [Re: Muscles] #1167715
01/29/12 04:41 PM
01/29/12 04:41 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Oil lines are recessed in the head forward of the back of the casting.
Re: 440-1 heads? [Re: B G Racing] #1167716
01/29/12 05:23 PM
01/29/12 05:23 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
Speaking of the oil lines are u guys running the 0.40 restrictors...i did not and to much oil up in head and the vacuum pump tank filled up in one pass....and overflowed..installed a baffle in the valve cover and moved the fitting to the front of the valve cover...any other secrets???? sorry for jumping on thread pattyboy
Re: 440-1 heads? [Re: pattyboy 572] #1167717
01/29/12 06:28 PM
01/29/12 06:28 PM
Western Kentucky
Muscles Offline
Muscles  Offline
Western Kentucky
I never did with indy rockers...I do with spray bars though for T&D rockers.
Re: 440-1 heads? [Re: Muscles] #1167718
01/29/12 06:30 PM
01/29/12 06:30 PM
new york usa
P
P
new york usa
they are t&ds by the way on 325s no spray bar , shaft oiling
Re: 440-1 heads? [Re: pattyboy 572] #1167719
01/29/12 08:16 PM
01/29/12 08:16 PM
I use a #10x32(maybe #6x32 sbrass set screws, CRS) screw in Holley air bleed with .021 orifice size and then drilled it out to .039 I installed both of them, one for each line, in the bottom of the male 8/ NPT to 1/4 inch flare adapter going to the oil line to the heads from the T in the block I have a set of single shaft T&D on my SR headed street motor and a set of Harland Sharp single shafts on my 440-1 bracket motor, both with .039 ristrictors now. I treid .120. 085 and now the .039, they seem to work the best so far, I'm a little leary to try and go smaller.
Re: 440-1 heads? [Re: Moparpoor] #1167720
01/29/12 08:17 PM
01/29/12 08:17 PM
the lines on my street motor I run a electric oil presure gauge as well as electric oil temps, that the reason for the plumbing nightmare on this motor
Re: 440-1 heads? [Re: Cab_Burge] #1167721
01/29/12 08:58 PM
01/29/12 08:58 PM
new york usa
P
P
new york usa
Indy suggested 0.30 restrictor for strictly track..since my 572 sees more street they ,suggested to go with 0.40....cab burge i to also run an electric gauge, what i choose to do was run a steel brade line in the car and then install the sender,,,so far no tech issuse...gave me much more room... pat
