2001 Chrysler 300M Engine Noise:
#1167596
01/29/12 03:06 AM
01/29/12 03:06 AM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
I posted about this once before, but nobody really seemed to KNOW this symptom - only some speculation. On cold starts only, the 3.5L makes some pretty significant noises, & when you put it in gear or under any load, the noise becomes a racket! After the engine warms up a bit - maybe 5 minutes, the noise seems to almost go away completely. The sound is almost like a heat shield or something rattling or vibrating - it is not a real consistent sound though. I thought it was maybe loose bricks in the catalytic converters - it really sounded like this. I replaced those a couple months ago & it was not them - heck the original cats were fine. The sound seems like it's coming right out of the engine when you listen with the hood up. The last time I posted, one speculation was piston slap. The sound does not sound like it's coming from deep inside the motor & does not sound like a ticking or lifter noise at all.
Anybody else ever experience or diagnose this one? (car has around 127,000 on it & runs great!)
Re: 2001 Chrysler 300M Engine Noise:
[Re: Sunroofcuda]
#1167597
01/29/12 03:11 AM
01/29/12 03:11 AM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I haven't got a clue. My Concorde Limited (300M with a trunk) has 98,000 miles and never did anything like that. Have you put it on jack stands and crawled under it to listen for the noise? Try using a solid bar (big screwdriver) held against different things or a piece of tubing held in different areas to listen for the noise. If it's getting loud, you're getting close.
BTW... did you do the timing belt and water pump yet?
[Re: Sunroofcuda]
#1167598
01/29/12 04:28 AM
01/29/12 04:28 AM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
Does any part of the exhaust system have bolts with springs? I had a Honda in Ohio that would make weird rattly noises until the exhaust system warmed up and expanded. Fixed by replacing some rusty springs at one of the exhaust flanges.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: None2Slow]
#1167600
01/29/12 09:58 AM
01/29/12 09:58 AM
Posts: 654 Westfield, MA
rbrogle
super street
super street
Westfield, MA
For a change, I can shed some light, and high mileage experience as well. As of yesterday I now have 2 300m's, a 2000 and a 2004 Special. My 2000 is about 90 miles away from hitting 300,000 miles. I also had the tapping noise that you describe at around 140,000 miles. I thought it was an exhaust leak, so I kept driving it until I had time to deal with it. During that time, I never babied the car and ran up close to another 20K on it. It turns out that I had 3 lobes wiped off one of the cams! This was with synthetic oil since I bought it a 33K. I had a good, then unempolyed Mopar mechanic of mine discover this. He ended up replacing the cam (pass. side I think) and all of the combo rockers on that side. The head needed to be pulled to accomplish this. That cured it. The car still runs well (taps somewhat now on startup in the cold) but only uses a quart of Mobil 1 10W30 in about 5000 miles. My only other advice if you do this work would be to use a MOPAR HEAD GASKET. Good luck!
Rob
'70 Fury III 'vert (GT Clone)was 318 3 on the tree,now 440 automatic
'68 300 2 Door HT vinyl/cloth bench
'68 Newport Custom 4 Dr. HT, 383/2, FULLY LOADED!
'68 New Yorker 4 Door HT, 440/Auto, loaded!
2004 Chrysler 300M Special daily driver
[Re: Sunroofcuda]
#1167602
01/29/12 11:57 AM
01/29/12 11:57 AM
Posts: 2,415 Connecticut
Ron_M
Connecticut
You are not alone with this. My 2000 Concorde with a 1999 300M engine does this. I just tolerate it and let the car warm up before I go.
When my mom had her Saturn SOHC, that thing would wrap like crazy upon startup (dealer tech said it was piston slap / tolerances on the bearings) until it warmed up and what did that car in was the horrible bang experienced when the transmission was put into reverse. Drove that car straight to the auto recycler.
Common sense is a flower that does not grow in everybody's garden
[Re: rbrogle]
#1167603
01/29/12 10:38 PM
01/29/12 10:38 PM
Sunroofcuda
Highland, MI.
Good luck!
As far as the water pump & timing belt, this was done at a Dodge dealer when the car had about 90,000 miles on it. The car was a one-owner meticulously maintained car - all service performed at the original Dodge/Chrysler dealer where he bought the car. I don't even take as much preventive care with my own cars as this guy did. Anyway as far as the cam lobe issue, would this only happen when the engine is cold & then go away? I would think if cam lobes were messed-up, the engine would run like crap?? The sound does seem to come out of the top-end of the motor. I'll do a video & post it on YouTube so you can all hear this. Stay tuned for the link. I'll try & do this this evening. My camera does pretty good movies & good sound.
[Re: Seth_Jones]
#1167606
01/30/12 03:21 PM
01/30/12 03:21 PM
Sunroofcuda
Highland, MI.
I took a couple movies of it this morning on cold start with all the racket. I'll get another movie later when my wife gets back when it's warm. Stay tuned.
[Re: Sunroofcuda]
#1167610
01/31/12 10:45 PM
01/31/12 10:45 PM
Sunroofcuda
Highland, MI.
*BUMP*
Anybody else with any ideas on this?
