Lunati 60402 #1167245
01/28/12 04:02 PM
01/28/12 04:02 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..anyone using this cam:
..how does it perform ...
Re: Lunati 60402 [Re: can.al] #1167246
01/28/12 04:07 PM
01/28/12 04:07 PM
Kirkland, Washington
Pacnorthcuda Offline
the O2 series (60302/60402) is pretty mild. 1 step over stock really. Lots of low end. I run the 03 in a 440, pretty much a mid-level street grind.
Low duration, fast ramp cams, little lope (none really with the 02)
Re: Lunati 60402 [Re: Pacnorthcuda] #1167247
01/28/12 04:16 PM
01/28/12 04:16 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I have the BB version (60302) in a 400. More power than stock but still has a stock sounding idle.
I'd run the 60402 in a low comp 318 or 360, but if your at 9:1 or so I go one step bigger to the 60403.
Re: Lunati 60402 [Re: 440newport] #1167248
01/28/12 05:58 PM
01/28/12 05:58 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
warm sm blk,9.5 : 1
i thought stock heads (x) wouldn't gain much above .480 lift?
