Re: Trunk mounted battery.....how do YOU route the cable?
[Re: Kern Dog]
#1166995
01/28/12 08:29 AM
01/28/12 08:29 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I've had a trunk mount battery (Direct Connection kit) in my Challenger T/A for about 30 yrs, no issues, cable mounted inside under the carpet, tucked inside drivers sill, over the rear wheel well, clipped along the underside of package tray/rear qtr,...battery on the PASSENGER side...use a grommet where it passes thru the firewall to the starter, on an auto car, you could use the clutch rod hole, I prefered to exit just under the firewall pinchweld flange...but again use a grommet and secure the cable WELL, as it will be the biggest smoldering wick if you hack it in the car
[Re: DAYCLONA]
#1166996
01/28/12 10:02 AM
01/28/12 10:02 AM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Exactly how I did the Charger. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: Rhinodart]
#1166999
01/28/12 11:53 AM
01/28/12 11:53 AM
Posts: 1,973 SoCal
jake4cars
SoCal
The one on my 67 Dart GTS chafed through the firewall grommet and set the car on fire! Make sure to use a nice, thick grommet and check it periodically!
I always run mine under the car for this very reason, you can tuck it up nicely against the body channel or in my case, the subframe connectors, it always amazed me that NHRA let them in the interior, oh wait!, nothing surprises me when it comes to NHRA's train of thought.
Joey
[Re: jake4cars]
#1167001
01/28/12 12:28 PM
01/28/12 12:28 PM
Posts: 21,824 Kirkland, Washington
Pacnorthcuda
Joey
UNDER the car, not in the interior! Along the frame sections and subframes! Fire is a bad thing.
[Re: AndyF]
#1167003
01/28/12 02:05 PM
01/28/12 02:05 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
You need to make sure the feed is dead when not cranking, otherwise you are really risking a dead short on a very large gauge cable. It is not possible to fuse the starter feed due to the high amp draw so use a Ford-style relay with a feed from the switch that has a fuseable link.
As far as the routing under the car seems safer although both ways can be safe as long as you do it right.
383, Hemi 4-Speed, AlterKtion, D60
[Re: Crazy68Dart]
#1167006
01/28/12 03:08 PM
01/28/12 03:08 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
WINNER!
Grommets on a high amp line like that, use a pass through. Nothing like a 1 gauge unfused wire going to ground.
