Re: Help diagnose engine trouple
[Re: Redleg]
#1166190
01/27/12 08:10 PM
01/27/12 08:10 PM
RapidRobert
Not sure on the tapping noise. intake gasket on the smoke. Vac leak on the rest EDIT what brand cam/lifters as some are way too noisy brand new
[Re: Redleg]
#1166191
01/28/12 02:41 PM
01/28/12 02:41 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Did you built it? I guess not. Take it back to who did and ask them to look at it. Sounds like a lifter is ticking and it has some other issues. The smoking out 1 side is not a good sign.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: stumpy]
#1166195
01/28/12 05:26 PM
01/28/12 05:26 PM
Posts: 36 Goodyear, AZ
Redleg
Goodyear, AZ
Ok, I'll look into that. How do I test lifters? Also all the rockers are on a single shaft. what are the torqu specs for the shafts bolts? There are two Rockers that slide from side to side a tad.. This could be where my Tapping noise is coming from?
1977 D-150 Warlock 360/727
2021 Challenger T/A 392/M6
Its pronounced Dirte'
[Re: Redleg]
#1166196
01/28/12 07:39 PM
01/28/12 07:39 PM
Posts: 1,012 indiana
mcmopars
indiana
Found the reason for the smoke I believe. Fuel in the oil... Now to find the culprit for that!
i think it would smoke out both sides if that were the case.
[Re: Redleg]
#1166198
01/28/12 08:38 PM
01/28/12 08:38 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
Two things come to my mind when you say fuel in the oil , 1. is the float set to high in the carb or is the carb old and needing rebuild ? 2. How long did you run it with gas in the crank case? Because it is very hard on the bearings. I also would due a compression test on all 8 cylinders to see what you have and post the results .
1969 Dodge Charger
1969 Dodge Superbee
[Re: Redleg]
#1166200
01/29/12 06:10 PM
01/29/12 06:10 PM
Redleg
Goodyear, AZ
Here is a youtube video of the engine running and horible noise that makes me cry. Engine Noise
[Re: Redleg]
#1166201
01/29/12 11:16 PM
01/29/12 11:16 PM
Posts: 1,532 crisfield, maryland 21817
82ramIndy493
Out of curiosity what is the oil pressure reading on your engine from cold to hot? Also check to make sure your rocker shafts are installed correctly. The oil holes in the shafts should be facing down into the rockers. If they are facing up you need to turn them over the other way. Are your rockers factory hydraulic type or adjustable? Can you give a breakdown of how the engine was built parts wise?
[Re: calrobb2000]
#1166204
01/30/12 03:30 PM
01/30/12 03:30 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
hi look for a bad fuell pump diaphram as a possiable cause of oil contamination !
and what type of carb may be leaking raw fuel into it at idle and when shut off!
