head bolts ? #1166183
01/27/12 08:02 PM
01/27/12 08:02 PM
south carolina U.S.
DOUGG Offline OP
DOUGG  Offline OP
south carolina U.S.
how many times can factory b/rb head bolts be used/torqued before being replaced?
Re: head bolts ? [Re: DOUGG] #1166184
01/27/12 08:12 PM
01/27/12 08:12 PM
As many as you desire EDIT I'd want to chase the threads w a "thread chasing" tap as opposed to a regular metal cutting tap, lightly wire brushing the bolt threads, making sure the bolts do not bottom, lube threads w 30 wt eng oil then blowin them off w shop air, multiple torque sequences, eyeball the bolt threads for any nicks/damage. #1 decks (head & block) milled flat, slight chamfer on deck bolt holes, a bit anal but that's me
