1971 B Body Rag Joint #1166102
01/27/12 05:56 PM
01/27/12 05:56 PM
Ohio in the USA
O
Omni Source 1 Offline OP
O
Ohio in the USA
Good Day All
Acquiring the parts to complete the install of tilt steering into a 1971 Charger.
Any sources for the 'rag joint' insert?
Thanks to all who respond.
Omni
Re: 1971 B Body Rag Joint [Re: Omni Source 1] #1166103
01/27/12 06:25 PM
01/27/12 06:25 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
What is the column out of? I don't remember my '71 tilt column having a rag joint.
Re: 1971 B Body Rag Joint [Re: NicksGarage] #1166104
01/27/12 09:54 PM
01/27/12 09:54 PM
Ohio in the USA
O
O
Ohio in the USA
The column is out of a 1972 Road Runner, column shift.
Omni
Re: 1971 B Body Rag Joint [Re: Omni Source 1] #1166105
01/27/12 10:17 PM
01/27/12 10:17 PM
md
mopars4ever Offline
mopars4ever  Offline
md
73 b body used a rubber piece 3575303, I don`t think 72 used it.
Re: 1971 B Body Rag Joint [Re: mopars4ever] #1166106
01/28/12 03:24 AM
01/28/12 03:24 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
are you talking about the "biscuit?"
http://www.jimsautoparts.com/steering_parts.htm
Re: 1971 B Body Rag Joint [Re: dangina] #1166107
01/28/12 09:15 AM
01/28/12 09:15 AM
Ohio in the USA
O
O
Ohio in the USA
Probably. The piece is a made of sandwiched rubber (think of how a tire is constructed) that is at the bottom of the steering shaft between the coupler and he steering box.
Omni
Re: 1971 B Body Rag Joint [Re: Omni Source 1] #1166108
01/28/12 09:23 AM
01/28/12 09:23 AM
California
moparbroz Offline
moparbroz  Offline
California
End of Steering Column Shaft Black (as original) Rubber SEAL
Hebrews 11:1
Re: 1971 B Body Rag Joint [Re: Omni Source 1] #1166109
01/28/12 01:26 PM
01/28/12 01:26 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Omni
72 RR didnt have a rag joint. 73 and up
Re: 1971 B Body Rag Joint [Re: CYACOP] #1166110
01/28/12 04:44 PM
01/28/12 04:44 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Omni
Right. It was needed because of the flexi-flyer rubber-isolated 73-up K.
Rick
