Re: 1969 1/2 K-Frame differing types and styles
[Re: six-pack-mopar]
#116594
09/07/08 03:34 PM
09/07/08 03:34 PM
Posts: 6,301 colorado
a12superbee
colorado
I'm not sure what your question is, I haven't gotten a full cup of coffee in me yet, but the easiest way to tell if it's original is the date code on the front of the k.
Opps, I should add, all the k's we've (the a12 guys) discussed or photographed have been the same regardless of the vin.
I can't afford this.
mark
[Re: JDMopar]
#116596
09/07/08 10:08 PM
09/07/08 10:08 PM
Posts: 21,522 N.E. OHIO, USA
A12
N.E. OHIO, USA
I think I read on here once that M code cars had a k frame with a 69 top with a 70 bottom welded to it, but still used the 69 sway bar. As far as part numbers.......not a clue!
Here is the K-frame that is found on most of the A12's even the earliest production models. I think even the A12's without the "A12" on the fender tags had this type of K-frame?
MikeR
[Re: LYNCHROAD69.5]
#116599
09/07/08 11:52 PM
09/07/08 11:52 PM
A12
N.E. OHIO, USA
Correct. Picture below should explain what is correct for A12 K-frame. That's wierd same pic just got posted as I was replying.....cool.
Wayne, that's my K-frame that I did that text on a few years ago. Here's the top of that same K-frame and you can see the '70 swaybar mounts are not drilled through.
MikeR
[Re: JDMopar]
#116600
09/08/08 12:11 AM
09/08/08 12:11 AM
A12
N.E. OHIO, USA
Anyone have part numbers for the '68/'69 K-frames?
Were the 318, 383 (and 440) K-frames the same?
[Re: A12]
#116602
09/08/08 10:29 AM
09/08/08 10:29 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
MikeR
My friend has a June 69 build 383 car , has the exact same K, it's only A12 specific because there was a change made during the production run in preparation for the next model year since the platform was still going to be the same and ALL 69 B bodies that received a V8 engine received that EXACT same K frame.
Different part number for the K used in a 68 vs. the one in a 69 even though everything else that was attached to it was the same ????
[Re: JohnRR]
#116603
09/08/08 01:22 PM
09/08/08 01:22 PM
A12
N.E. OHIO, USA
John, All V8's including the 318 had the same K-frame in '68/'69 B-bodies????
I had a '69 (Lynch Road) June 26 (626) SPD RR that had the '70 bottom K-frame too. Must have been a late March, Lynch Road change over...... just a guess ?
MikeR
[Re: A12]
#116604
09/09/08 08:58 AM
09/09/08 08:58 AM
JohnRR
U.S.S.A.
MikeR
Yes thats correct , small block big block same K , the rubber mounts were the same , only the engine brackets are different , trans mount in the same location also .
My friends runner is also a Lynch rd. car , no fender tag .
My 383 bee is a 2/10 SPD Lynch Rd car , it has the 68 style bottom , but it does have the oval fuel filler hole in the rear crossmember .
