Neon Check OIl Light comes on #1165958
01/27/12 03:32 PM
01/27/12 03:32 PM
1.5 hours SE of Pittsburg, Pa
geno440 Offline OP
geno440  Offline OP
My friend's Neon's oil light comes on when he goes around a sharp turn? Any ideas? He changed the oil and filter. It has plenty of fresh oil in it.
Love them 68 MOPARS! GTS 340 auto, Charger R/T 440 4-speed, Superbee 383 auto, GTX 440 auto, D100 (new front frame 5.7 hemi - in process), Formula S 340 4-Speed A/C (it's green), 383 auto Roadrunner (maybe a hemi - waiting) and a 68 W200 Power Wagon. Drivers: 07 Cummins and 14 Ecodiesel 4x4.
Re: Neon Check OIl Light comes on [Re: geno440] #1165959
01/27/12 11:24 PM
01/27/12 11:24 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
most likely an oil pressure switch going bad...you should put a gauge on it and check the pressure
Re: Neon Check OIl Light comes on [Re: AARCONV] #1165960
01/28/12 01:23 AM
01/28/12 01:23 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I hate to say this but check the oil again. The only time this happened to me in my '97 is when I only had about a quart left in the pan.
Re: Neon Check OIl Light comes on [Re: AARCONV] #1165961
01/28/12 02:33 AM
01/28/12 02:33 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Very common. Does he have a drip from the rear of the enigne? You can usually look up behind the backside of the engine and see oil dripping out of the oil pressure sending unit when it goes bad. Not expensive, but pick up the correct $11.00 sending unit socket to remove and install it while you're at it.
