Explain window lock strips to me #1165902
01/27/12 12:56 PM
01/27/12 12:56 PM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
I found a deal on some new windshields, and also scored some original window rubber in excellent condition. I have never removed/replaced front glass before, and don't understand the lockstrips. The cars in question are 69 Dart and 69 Satellite.
Did all Mopars with window gaskets use lockstrips? At what point in the installation sequence do you install them?
Re: Explain window lock strips to me [Re: Mike H] #1165903
01/27/12 02:18 PM
01/27/12 02:18 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Lockstrips go in last. The gasket is installed, the glass seated, then the lockstrip is wedged into the gap in the outside surface of the gasket to lock the glass in the gasket. Not all used them, but it does make installing a gasketed glass easier. There are a couple different tools to insert the lockstrip, but even with them it's a pain until you have lots of practice.
Mike
Re: Explain window lock strips to me [Re: 1E2C] #1165904
01/27/12 02:23 PM
01/27/12 02:23 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
..There are a couple different tools to insert the lockstrip, but even with them it's a pain until you have lots of practice.
Mike
Such as...
http://www.amazon.com/Lisle-47000-Windshield-Locking-Strip/dp/B000COA1CQ
And I did the lock strip on my old Aussie Charger years ago, and it was a pain at first but went ok as I went (and kinda practiced as I would go )
