Vally Plate ques. #1165757
01/27/12 12:08 AM
01/27/12 12:08 AM
NE
bigtail Offline OP
bigtail  Offline OP
NE
What vally plate works with 440 source heads, or are they all the same? Will INDY cast plate work ok? Thanks.
This page is made up completely of recycled electrons.
Re: Vally Plate ques. [Re: bigtail] #1165758
01/27/12 12:30 AM
01/27/12 12:30 AM
Idaho
LaRoy Engines Offline
Idaho
Use the stock style valley pan, it is the easiest to seal.
Re: Vally Plate ques. [Re: LaRoy Engines] #1165759
01/27/12 12:33 AM
01/27/12 12:33 AM
NE
bigtail Offline OP
bigtail  Offline OP
NE
I don't know why, but I really have my heart set on a cast aluminum plate. I seem to recall reading that some only work with certian heads?
Re: Vally Plate ques. [Re: bigtail] #1165760
01/27/12 12:41 AM
01/27/12 12:41 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
If you do go with a valley plate go with a plate with a removable center plate.I went with a solid plate and had regrets as soon as I started sliding the pushrods in.
Gus
64 Plymouth Savoy
Dana 60
Re: Vally Plate ques. [Re: bigtail] #1165761
01/27/12 02:00 AM
01/27/12 02:00 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Indy plates are sized for indy's heads on their perspective block height.
A plate made to work with an Ebrok head will work with the source head.
Re: Vally Plate ques. [Re: JohnRR] #1165762
01/27/12 10:05 AM
01/27/12 10:05 AM
NE
bigtail Offline OP
bigtail  Offline OP
NE
Thanks.
