Page 1 of 3 1 2 3
67 Dog Dish Hubcaps on Newer Steel Wheels???? #1164918
01/26/12 12:31 AM
01/26/12 12:31 AM
SK,Canada
gregsrt Offline OP
gregsrt  Offline OP
SK,Canada
Has anyone made a set of the older large diameter hubcaps (pre 67)fit on newer more common steel wheels? If so how? I thought of using some newer damaged dog dishes and epoxying them to the older hubcaps. Any ideas?
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: gregsrt] #1164919
01/26/12 12:34 AM
01/26/12 12:34 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Why not just buy some old wheels? They aren't that rare or expensive unless you buy 5.5 Hemi wheels.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: gregsrt] #1164920
01/26/12 12:47 AM
01/26/12 12:47 AM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
I had thought of this before and never tried it, but maybe weld some bar stock to the wheel center to make the hubcap register bigger? I dont know if I am describing it correctly but I can see it in my head Just one inch long sections right where the hubcap snaps on.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: ScottSmith_Harms] #1164921
01/26/12 12:50 AM
01/26/12 12:50 AM
SK,Canada
gregsrt Offline OP
gregsrt  Offline OP
SK,Canada
They are a little harder to find up here and I won't pay shipping(and duty) to get some here. I'm just throwing some ideas around. I'll probably just buy some wheels from Rocket racing.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: gregsrt] #1164922
01/26/12 01:08 AM
01/26/12 01:08 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I have a set of vintage used 65/66 KH wheels sitting here that will accept the large caps, I don't own them but the guy would sell them for $300.00 for all 4. If interested let me know. BTW, they are not Hemi wheels but do measure 14 x 5.5 and look very similar to them. If you are not in a hurry I can have one of my Canadian friends haul them up (likely for free) to either Kelowna BC or Edmonton Alberta.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: gregsrt] #1164923
01/26/12 01:31 AM
01/26/12 01:31 AM
That's exactly what I did.
PC7 epoxy and put the little 9" cap inside the 10" cap so I could run 8" Wheel Vintiqes steelies on the back of my '63.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? #1164924
01/26/12 02:19 AM
01/26/12 02:19 AM
SK,Canada
gregsrt Offline OP
gregsrt  Offline OP
SK,Canada
Interesting, so it does work. hmm now to decide if I want dog dishes or these wheels from Rocket.
Thanks for the offer Scott, I would consider it but I need 15" because I have the tires and I'm doing the front disc conversion and using the 11.75 inchers.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: gregsrt] #1164925
01/26/12 02:37 AM
01/26/12 02:37 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Another approach that might work well is to use spring clips like allot of earlier cars used... They are available for VW's & would probably work well for this too, just a little effort figuring out where to position the clips..
http://www.mamotorworkstv.com/vw/product/retaining-clip-rivet-set-hubcap-for-1-wheel_375591/
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: 1_WILD_RT] #1164926
01/26/12 10:13 AM
01/26/12 10:13 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
You could weld on the tabs on the newer rim to make them bigger so that the older cap will catch.
That's what I'm going to try to do.
If you are looking for the older style rim in a 15" size, good luck. Took me a long time to find mine.
You can find them on 60-66 dodge half ton pickups, Mid 60's studabackers, and on some 66-67 C-bodys
And they won't work with disc brakes.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: rapom] #1164927
01/26/12 11:33 AM
01/26/12 11:33 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
this is what i came up with some years back.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: lewtot184] #1164928
01/26/12 12:59 PM
01/26/12 12:59 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I am watching this post with great interest because I am in the same boat. The welding of the tabs looks like a great idea. I assume that it could be done to wheel vintique wheels which can be purchased in different widths and backspacing. One of the advantages to the early dog dish caps (other than being period correct) is that they should clear the long rear wheel studs that I have.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: rapom] #1164929
01/26/12 01:37 PM
01/26/12 01:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The spring clips come with rivets.. Just drill a few small holes & peen the rivets in place...
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: 1_WILD_RT] #1164930
01/26/12 02:07 PM
01/26/12 02:07 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
15X8 RamCharger rear,15X7 steel front,62 Plymouth 10" cap.Drilled and tapped three holes,oval head machine screws,cap snaps right on,perfectly centered.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: 62maxwgn] #1164931
01/26/12 02:08 PM
01/26/12 02:08 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Installed.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: 62maxwgn] #1164932
01/26/12 02:36 PM
01/26/12 02:36 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
This idea as well as the VW clip idea are very interesting and seem so simple that even a "caveman" like me could do it. What size machine screws did you use, and do you recall how you figured the exact drilling/tapping point?
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: rbstroker] #1164933
01/26/12 04:44 PM
01/26/12 04:44 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
That wagon is the cats a$$
I have mechanical Aptitude.
I can screw up anything.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: rbstroker] #1164934
01/27/12 05:29 PM
01/27/12 05:29 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Looks like I will have to stay with my prostars, I contacted Summit regarding the steelies available through Wheel Vintiques. I need 15X10 4 1/2"BS for the rear. They only offer 15X10 with a minimum of 5 1/2" backspace.
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: rbstroker] #1164935
02/02/12 10:53 AM
02/02/12 10:53 AM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
There was a guy in the Chicago area that made some adapters out of a thick plastic material. I think they were done on a CNC machine , good bit of waste. They didn't work well on the 3 tab wheels , but did work on the 4 tab later wheels.
I didn't get much interest from the Mopar people in them and they were kinda costly. I think I may still have the guys number , PM me and I will check.
Frank
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: duster2] #1164936
02/03/12 02:25 AM
02/03/12 02:25 AM
GA
roadrunninMark Offline
GA
talking about dog dish, do the "plymouth motor division" dog dishes fit both the 14" and 15" steelies or were there different sizes? These are the caps I am referring to:
Re: 67 Dog Dish Hubcaps on Newer Steel Wheels???? [Re: duster2] #1164937
02/03/12 02:37 AM
02/03/12 02:37 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
This is what 67 Plymouth B-body dog dish caps looked like (Belvedere/GTX)
Page 1 of 3 1 2 3
