Re: Stage 5 intake linkage
[Re: Hemi ragtop]
#1164801
01/26/12 12:28 AM
01/26/12 12:28 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I am using a Stage 5 open plenum intake with 2 750 vacume secondary square bowl Hollys on a 540 c.i. Hemi with a street roller (248i, 254e). A short drive with the carbs connected in sequence, (both carbs open together), produced an almost uncontrollable situation. Just a small amount of throttle puts the car sideways! I am thinking about using a progressive linkage that would open the rear carb first and bring the front carb in at approximately half throttle, more like factory HEMI linkage. My qestion is: would I risk a poor mixture distribution problem, (lean condition) by doing this? I intend to do a lot of street driving and cruising with the car and the violent drivability is a concern.
You built a monster of an engine , what did you expect ? Put smaller carbs on it, or change the intake.
Take a close look at the design of the stage 5 it's to small single plane intakes with a small passage between the 2 intakes , trying to run the carbs progressively is a bad idea with the design of the intake.
What kind of tires do you have on the car and what gear in the rear?
[Re: Hemi ragtop]
#1164803
01/26/12 02:17 PM
01/26/12 02:17 PM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
First I ever heard of an issue having too much power. Perhaps run a tall gear set, like a 323 or 307 rear end ratio. You wont get all that torque multiplication.
[Re: 2fast4yourBrain]
#1164804
01/26/12 02:40 PM
01/26/12 02:40 PM
Posts: 4,848 Memphis
HemiRick
Memphis
The smallest gear you can get for a Dana is a 3.54 so that idea wont work.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
