Best way to block off exhaust crossover on a 440? #1164083
01/24/12 02:36 PM
01/24/12 02:36 PM
A certified culture free zone.
74RALLYE Offline OP
74RALLYE  Offline OP
What's the best way to block off exhaust crossover on a 440 with iron heads and a Performer RPM intake?
I don't think I need the heat as this is a sunny day car.
Thanks.
Re: Best way to block off exhaust crossover on a 440? [Re: 74RALLYE] #1164084
01/24/12 02:41 PM
01/24/12 02:41 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
get a valley pan w/o the holes in it. Or you can cut up and old one and block them off yourself.
Coming soon!!!!
Re: Best way to block off exhaust crossover on a 440? [Re: Mr.Yuck] #1164085
01/24/12 02:43 PM
01/24/12 02:43 PM
74RALLYE Offline OP
74RALLYE  Offline OP
Just cut a rectangle and glue it in place?
Re: Best way to block off exhaust crossover on a 440? [Re: Mr.Yuck] #1164086
01/24/12 02:50 PM
01/24/12 02:50 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Mopar performance part number P4286825
Summit has it listed for $19.95
http://www.summitracing.com/parts/DCC-4286825/
I have mechanical Aptitude.
I can screw up anything.
Re: Best way to block off exhaust crossover on a 440? [Re: bboogieart] #1164087
01/24/12 02:54 PM
01/24/12 02:54 PM
74RALLYE Offline OP
74RALLYE  Offline OP
Thanks.
Re: Best way to block off exhaust crossover on a 440? [Re: 74RALLYE] #1164088
01/24/12 02:57 PM
01/24/12 02:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You should be able to buy it local thru felpro and save on the shipping .
Re: Best way to block off exhaust crossover on a 440? [Re: 74RALLYE] #1164089
01/24/12 02:59 PM
01/24/12 02:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Felpro 1215.
Re: Best way to block off exhaust crossover on a 440? [Re: stumpy] #1164090
01/24/12 03:02 PM
01/24/12 03:02 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i did this.
Re: Best way to block off exhaust crossover on a 440? [Re: 74RALLYE] #1164091
01/24/12 03:02 PM
01/24/12 03:02 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
that will work.
Re: Best way to block off exhaust crossover on a 440? [Re: lewtot184] #1164092
01/24/12 03:32 PM
01/24/12 03:32 PM
i did this.
Lewt I like that & I'm gonna try it. I like mileage/cold weather driveability on my DD
Re: Best way to block off exhaust crossover on a 440? [Re: RapidRobert] #1164093
01/24/12 04:21 PM
01/24/12 04:21 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i did this.
best of both worlds!
Re: Best way to block off exhaust crossover on a 440? [Re: Mr.Yuck] #1164094
01/24/12 06:22 PM
01/24/12 06:22 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I had one of those FelPro valley pans. The ports were stamped but not removed.
One of them blew out of the valley pan, went through the exhaust port, traveled down the header, and took out one of my turbos.
When you've got a turbine blade spinning at 100,000+ rpm it's not a good idea to toss a little chunk of sheet metal in there.
- Stu Harmon
Re: Best way to block off exhaust crossover on a 440? [Re: feets] #1164095
01/24/12 06:44 PM
01/24/12 06:44 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I have never done it this way but I have had a Bud weld-in(tac-in) ONLY ON ONE SIDE a little square plate IN the intake cross-over port.
Re: Best way to block off exhaust crossover on a 440? [Re: dOc !] #1164096
01/25/12 03:58 AM
01/25/12 03:58 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I just have my intake welded up. Ron
Re: Best way to block off exhaust crossover on a 440? [Re: Mr.Yuck] #1164097
01/25/12 04:09 AM
01/25/12 04:09 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I did this...
Re: Best way to block off exhaust crossover on a 440? [Re: 74RALLYE] #1164098
01/25/12 05:21 AM
01/25/12 05:21 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Aluminum heads do a good job of removing that pesky crossover
Re: Best way to block off exhaust crossover on a 440? [Re: 1_WILD_RT] #1164099
01/25/12 07:33 AM
01/25/12 07:33 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I did this...
Me too
Re: Best way to block off exhaust crossover on a 440? [Re: bobs66440] #1164100
01/25/12 09:45 AM
01/25/12 09:45 AM
74RALLYE Offline OP
74RALLYE  Offline OP
I like the idea of plugging the heads. It seems like that would keep more heat away from the intake. I may be able to have the ports on the intake welded shut instead as my heads are cast iron.
What driving conditions benefit from having the exhaust crossover open? Is it needed?
Re: Best way to block off exhaust crossover on a 440? [Re: 74RALLYE] #1164101
01/25/12 11:16 AM
01/25/12 11:16 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Cold mornings , cold weather driving .
Re: Best way to block off exhaust crossover on a 440? [Re: lewtot184] #1164102
01/25/12 11:37 AM
01/25/12 11:37 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
i did this.
WOW! NICE!.
done at manifold I guess! I don't find a place in head to make that
Wondering about leaks through the lever shaft hole ?
