Re: Don't use nice headers during break-in?
[Re: dfsmopars]
#1163779
01/24/12 12:35 AM
01/24/12 12:35 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Another reason to do your break in on a test stand or better yet a dyno...
[Re: tubedriver]
#1163784
01/24/12 10:40 AM
01/24/12 10:40 AM
Challenger 1
Cincinnati, Ohio
My TTI headers got toasted....Don't know whether to recommend just making it richer to start with, but the idle mixture setting from the stock heads was enough lean with the new Indy heads at idle to make the headers glow in short order, like real fast! So my headers are cooked.
Mine too when I first started my 440 back in 2005. It's hard not to get them cherry red when you are reving at 2000 rpm for 20 minutes. Use junk headers first during break in. My
[Re: babarracuda]
#1163788
01/24/12 11:29 AM
01/24/12 11:29 AM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
A flat tappet 20 minute run-in DOES NOT have to be all in one shot.
As long as it fires up instantly without any excessive cranking....5 minutes at a time, or 10 minutes at a time works just fine.
Let it cool off between runs, and then do another run until your total equals at least 20 minutes.
The idea is to run in the cam and lifters, establish lifter rotation and a wear pattern. The oil and coolant temp, as long as within safe limits, can be on the cold side during the process and it will not do any harm whatsoever. There is no need to melt it down trying to do it all in one shot.
Rich H.
Esse Quam Videri
[Re: dfsmopars]
#1163789
01/24/12 11:51 AM
01/24/12 11:51 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Some say yes, some say no,....personally in 30 yrs of engine building, and countless break ins, avg 2000 RPM@20-30 mins.....I've never "fried" a set of headers, even nickel plated, chrome, painted, or ceramic coated units, including TTI's I do make sure all perimeters of the engine are set before firing, and all external sensors, gauges, timing equipment, etc, is attached ready to go
[Re: DAYCLONA]
#1163790
01/24/12 12:58 PM
01/24/12 12:58 PM
Posts: 5,902 Athens, Greece
Pyper70
Athens, Greece
.............or get a roller setup and avoid having the the cam-break in procedure...
When I do my 505 break-in (if I hadn't bought the roller setup) I would have a proven manifold, carb, throttle setup. All I would need to do is set the timing on the mark and I am good to go. Any way you can pull an existing working setup from another car and use the induction side that has the best results?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#1163791
01/24/12 01:06 PM
01/24/12 01:06 PM
Posts: 16,619 Almost Heaven
B_Body_Bob
Master of nothing
Master of nothing
Almost Heaven
If it's an auto you might want to think about putting it in neutral instead of leaving it in park. Remember the pump doesn't run in park, the fluid is your lube, and 20 minutes is a good chunk of time.
Everybody makes fun of a hillbilly until they need something fixed
[Re: Pacnorthcuda]
#1163795
01/24/12 10:55 PM
01/24/12 10:55 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
yep I have never had a problem with messing up headers during break in.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dfsmopars]
#1163796
01/26/12 12:45 AM
01/26/12 12:45 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
OK, which one of you Masters want to come to the great state of KY and help start this thing up in a few weeks? This is my first solo build and start up so I am a little nervous. I am ready to get it over with so I know everything is OK. I still have a little work to do to get ready. Mount the electric fuel pump, new carb, new linkage, headers, front end accessories, oil it, valve covers and hook it all up. Question, if I am at TDC and the crank mark is right before zero on the timing chain cover isn't ths a good place to start?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
