Which 6.4 wer talking about the factory SRT version or the 6.1 based 392 version.
The srt version you will have to change a few things over. The stock 6.4 intake will have to be changed to the 6.1 version as the 6.4 has a variable length runner system that you can't control as of yet. Then you would have to change the tone ring on the crank and the crank senors to the older 6.1 version to run it.
The 6.1 version of the 392 there is alot more options to get her running but that cost 14-15k for jus tthe engine
