Re: 5.2 Magnum engine with 727 transmission. [Re: old97] #1163465
01/27/12 11:26 PM
01/27/12 11:26 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
The transmission is not the issue. Making the computer happy is what needs to be done.
Verifying it has a Park Neutral switch input & brake switch input, as well as vehicle speed is what need to be accomplished.
I have ran an auto trans pcm in a manual trans dakota, and no drivability problems. I would verify the other stuff first.
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: 5.2 Magnum engine with 727 transmission. [Re: wldtm] #1163466
01/27/12 11:49 PM
01/27/12 11:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What year Dak?
It makes a difference.
Don't be the exception.
Re: 5.2 Magnum engine with 727 transmission. [Re: Supercuda] #1163467
01/28/12 12:41 AM
01/28/12 12:41 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
94/95 - the OP was talking about obd 1. mine was the same year.
I have helped with this exact swap, and actually made the harness for the swap. if you really want to keep the efi and the 727, it is very doable.
Re: 5.2 Magnum engine with 727 transmission. [Re: wldtm] #1163468
01/28/12 01:21 PM
01/28/12 01:21 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
nothing like hands on experience.
Re: 5.2 Magnum engine with 727 transmission. [Re: wldtm] #1163469
01/29/12 10:05 PM
01/29/12 10:05 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Sounds to me like you may have a market for such a wiring harness. There are a lot of people that would love to put EFI on older Mopars. If your harness would accomplish that, I think you could sell a bunch of them. Gene
Re: 5.2 Magnum engine with 727 transmission. [Re: poorboy] #1163470
01/29/12 11:35 PM
01/29/12 11:35 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Unfortunately not so. I have two cars done in running (both friends/family). I have advertised for about 6 months, and havent sold one. They are 275 for just the harness. I thought that was very reasonable.
Oh well...
Re: 5.2 Magnum engine with 727 transmission. [Re: wldtm] #1163471
01/30/12 04:50 AM
01/30/12 04:50 AM
IL
O
old97 Offline OP
old97  Offline OP
O
IL
Oh well...
I just may need one of your harnesses to solve this issue. But it won't be for another couple of months. Working on other projects at present time.
Re: 5.2 Magnum engine with 727 transmission. [Re: wldtm] #1163472
01/30/12 01:49 PM
01/30/12 01:49 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
Oh well...
Justin, I have 2 projects that will need your harness's, but they keep getting put on the back burner and no money at this time to put into those projects, but soon I hope and we will be in touch. Ron....
Re: 5.2 Magnum engine with 727 transmission. [Re: old97] #1163473
01/31/12 12:33 PM
01/31/12 12:33 PM
IL
O
old97 Offline OP
old97  Offline OP
O
IL
In my original post I mentioned the speed sensor for the VDO speedometer. I also stated there was no other electrical wiring on the 727. That is wrong, I completely overlooked the neutral safety switch which is wired and working properly. My mistake.
