5.2 Magnum engine with 727 transmission.
#1163445
01/23/12 03:33 PM
01/23/12 03:33 PM
Posts: 13 IL
old97
IL
Four years ago I purchased a 1939 Dodge pickup model TC. The seller started the project and never finished it. I was told it was 80% done. What I wasn't told it had 80% left to go.
Here is the deal. The truck has a 5.2 Magnum engine (completely stock) from a 1994 Dakota. It has a 1983 727 Torqueflite transmission.
For obvious reasons, this is a total mismatch. The 5.2 is computer controlled, and the transmission is hydraulic. I was assuming based on the 1994 model year engine that this is an OBD-1 system that only controlled the engine diagnostics, and not the transmission.
Well guess what? I have two codes showing on an OBD-1 scanner. The codes are open, or short, in the overdrive solenoid relay, and open or short in the torque converter lockup relay. Apparently the computer is trying to analyze systems that do not exist on the 727.
Having said all of the above, here is my only real issue. I can run the truck up to 60 mph and it will run all day long real well. However when coasting down through the 45 mph range, the engine shuts down. Not every once in a while, but every single time.
Now, I can go to neutral and restart the engine, and as long as I stay under 45 mph, the truck runs good. But when you take it back up to 60 mph and then coast down to the 45 mph range, it shuts the engine off.
I am at a loss to even try to figure this problem out.(other than change the transmission and get one from a 1994 Dakota and get it wired into the computer).
BTW..The 727 transmission does a speed sensor solely for the VDO electronic speedometer. There is no other electrical wiring on this transmission. The speed sensor, which came with the speedometer is wired to the speedometer, and nothing else.
Does anyone have any ideas to overcome this mismatch to where the truck will coast down past the 45 mph range without shutting the engine off?
Re: 5.2 Magnum engine with 727 transmission.
[Re: fstfish66]
#1163450
01/24/12 11:25 AM
01/24/12 11:25 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I'm thinking you need a vehicle speed sensor of some sort...that and getting the computer reflashed to a manual tranny, or adding into the harness some dummy loads (resistors) for the missing sensors...
I have a manual tranny computer for sale, but it's for a '96 ram 1500, so it's the OBD2-jtec controller. dunno if it'll plug into the older harness.
[Re: old97]
#1163452
01/24/12 06:29 PM
01/24/12 06:29 PM
Posts: 1,757 levittown pa
fstfish66
levittown pa
Thank you all for your replies and assistance. They all seem very logical to me. I did not include this thought in my original post because it was getting rather long. I have given consideration to converting the 5.2 Magnum engine over to carbureted and just doing away with the computer. I am sure this would open a whole new can of worms.
For one thing, we are running an electric fuel pump which is delivering a confirmed 50 psi. That is way to much pressure for a carb, right? I haven't checked on a fuel pressure regulator yet, but surely one is available.
To use a mechanical fuel pump, which this engine wasn't designed for, requires an older LA 318 timing cover, longer cam shaft to run the pump,etc. and I just don't care to get that involved. My skills are somewhat limited. However, I will through this thought out there for your opinions and see what you all think. I am not really looking for a cheap fix for my issues, just the easiest one. Thanks again for your replies.
switching over to a carb isnt that hard at all,,,mancini,jegs,summit, all sell edelbrock or the mopar carb 4 bbl intake manifold for this conversion,, yes you will need a pump with way less pressure,,6 psi is about the most a carb can handle,, if you want to use a manual fuel pump, get the older LA timing cover and water pump, then i would assume, but dont know you will probably have to get the belt pullys for that style water pump,eigher a V belt or modern serpentine style from march pulleys,,
you do not have to get a longer cam, hughes performance makes a buttom that goes on the cam for the fuel pump excentric, it just bolts on,,
i think its easy enough to put an 02 sensor bung in ur exhaust,,send the wiring harmness to hot wire or some oen like them do a reflash on the computer and run the factory injection..
akso with the carb conversion it would be better to use a vacuum dizzy instead of the dizzy from the computer motor, but it will work,,,just less fuel mileage,,if u convert, hope this isnt comfusing to you
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#1163453
01/24/12 10:39 PM
01/24/12 10:39 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Resistors won't work to fool the computer. You need a relay. When relays de-energize the collapsing magnetic field creates a voltage kickback, this kickback is what the computer is looking for. Resistors will not do this. You might be able to just hook some relays to the wiring that control nothing so mimic the kickback. But I am not sure it would fix the engine shut off issue. I think it would be wise to consider swapping in the trans the computer is looking for, OD will help mileage.
[Re: Supercuda]
#1163454
01/25/12 03:07 AM
01/25/12 03:07 AM
Posts: 13 IL
old97
IL
I really do agree that a tranny swap would be the easiest way out of this mess. I believe the 94 Dakota's had 46RE transmissions. I would need to insure it would have a wiring harness with it. The challenge then would be to get it wired to the computer. And I do have the entire 94 Dakota wiring diagrams (46 pages worth). Thanks to all for your input, and suggestions.
BTW..There was a suggestion to add an O2 sensor. The truck already has one. However, the truck has true duel exhaust, but it only has one O2 sensor on the right side exhaust pipe, about 8" below where it attaches to the exhaust manifold. There is no sensor on the left side exhaust. And it has Magnaflow mufflers, and there are no catalytic converters. This all adds up to very little back pressure.
[Re: old97]
#1163455
01/25/12 09:28 AM
01/25/12 09:28 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
so there is a speed sensor installed and working? the fuel injector cut-off on coast down kicks in when the PCM detects a slowing vehicle speed, higher vacuum signal than idle, and a closed throttle. it stops grounding the injectors as a way to save a small amount of fuel, and yes, the transmission will be in "converter lock-up" at the same time to stop the engine from stalling out completely. the PCM will turn the injectors back on at around 22mph...of course, if you have a non-lock up converter, that's not going to matter.
I think you have 2 options here. either A) get the right trans and wire it in place, giving you OD and torque converter lock-up both of which will help improve mileage, or B) put a carb intake on it.
all you REALLY need to run the engine via carb, is the intake, carb, older electronic distributor with an orange box or MSD type ignition, and a fuel pressure regulator to dial down the pressure at the carb. the magnum/carb intakes are pricy, or you can hit *shudders* ebay, and pick up a generic "dual bolt pattern intake" for about half price. it's a dual bolt pattern (LA/Magnum) copy of the air gap intake. just search for "Magnum/LA intake" it usually pops up
**Photobucket sucks**
[Re: 70Cuda383]
#1163456
01/25/12 12:26 PM
01/25/12 12:26 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
But be aware that there are 2 dual-pattern intakes out there. One is the Professional Products Crosswind, which is around $230, and a ProComp, which sells for $170.
I've never held a Crosswind but I have a ProComp at home. It's a pretty crude-looking piece, with lots of ugly casting and presumably some coreshift also (mine has grinding marks in most of the runners at the head surfaces).
Considering the cost of the intakes, I would try to correct this EFI issue first -- especially since it's already installed and is mostly operational.
[Re: Fury Fan]
#1163457
01/25/12 12:45 PM
01/25/12 12:45 PM
Fury Fan
Indiana
I think some folks have hit on the right points. this response is long but I think it needs to cover all my thoughts.
I also believe the Maggie ECM is cutting fuel during your coastdown. Ford’s EEC-IV did this on the 5.0 in the 80s-90s (other OEMS do it too, but I’m not familiar with them). Parameters required to prevent a stall (and this should be pretty universal) are sufficient vehicle speed, closed throttle, high vacuum, and above 1500 engine RPM (that’s a Ford # there). My 88 Lincoln LSC has a MPG computer and it is really evident when fuel-cut kicks in, to the point that it is advantageous to coast down long highway hills in D instead of OD so as to stay above 1500. The max coasting # I’ve seen is around 150 MPG during a 75mph coast. Anyway…
You have an OBD1 ECM that does not control the trans shifting but it does control the OD and LU, and LU is your main problem. Torque converters are not as effective in back-driving, so when the fueling stops, the engine compression stalls the converter, and the engine stops immediately.
Your 2nd ‘problem’ is that without OD you’re probably above the 1500 during every coastdown. You could wire a switch to the ECM so that OD is always off, and that will solve 1 diagnostic code (but that shouldn’t be causing you any issues anyway). The LU solenoid needs to be solved. I am surprised that the ECU is still doing the fuel-cut when it is not getting vehicle speed info (VSS) and sees a LU solenoid problem. Bad design/response. VSS info is crucial for smoothenss when vehicle speed slows approaching a stop, so sending those wires to teh ECM might be a future issue. Pulses/mile of the VDO sender may/may not be compatible, will make the ECM think you’re going slower/faster than you are and that might lead to buck at slow speeds if the fuel’s cutting off.
Your options: There is a 727 that has electronic LU but they aren’t real common. I believe they are from the TBI truck/van years of 88-91 (I’ve read about them on here). I think the LU is hydraulically activated but the solenoid releases it (or vise versa) so that may not mesh with the Mag ECU if it is running an on/off solenoid. Although, if the Mag and TBI LU is wired differently, you might be able to use a relay to reverse the logic in between.
Next option is a hydraulically-goverened A500 or A518, of course.
BUT… But since the ECU is cutting fueling anyway, maybe a hydraulic LU setup would work? I would think an 83 727 would be LU unless it came from a 3500 van or something HD. Torque converters are not as effective in back-driving, so when the fueling stops the engine compression stalls the converter.
Does your current trans have LU? When does it disengage?
And – If you decide to go carb, be aware some fuel pumps may not like being choked from 50 psi down to 5-7 and it may shorten their life. You might not notice this until you go thru 2-3 pumps and see a pattern, harder to notice if you don’t drive it often.
Please let us know how this goes, I think a few of us are interested in the solution!
[Re: Fury Fan]
#1163458
01/25/12 09:38 PM
01/25/12 09:38 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
I wouldnt opt for a different trans or carb just yet. I helped a friend do a conversion harness for a OBD1 harness into a 68 Fury with a regular 727. He ran a summit speed sensor to the pcm for vehicle speed. He used the auto trans computer for awhile and no issues. He did have this issue previous and the vehicle speed sensor issue fixed it. I personally think/know the trans codes are not your issue. I believe it is the lack of vehicle speed input to the ECM. I would recommend using this interface http://www.ebay.com/itm/DAKOTA-DIGITAL-U...=item564844430fto get the desired signal to the ecm from your existing speed sensor. By the way, you may want to ensure the brake switch is wired to the computer as an input, along with the P/N switch. You want to ensure the engine knows the vehicles is in gear and when you are on/off the brake. I would also look for a manual trans/mopar performance pcm. It may have alittle bit better driveability to mimic more of how the computer is actually functiong (no trans controls what so ever). Look in the truck parts forsale section and there was a computer forsale there that may help. I would be happy to help trouble shoot farther if you want to PM me. The last option is sell it to me Good luck
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: old97]
#1163465
01/27/12 11:26 PM
01/27/12 11:26 PM
wldtm
Dayton, Ohio
The transmission is not the issue. Making the computer happy is what needs to be done.
Verifying it has a Park Neutral switch input & brake switch input, as well as vehicle speed is what need to be accomplished.
I have ran an auto trans pcm in a manual trans dakota, and no drivability problems. I would verify the other stuff first.
PM for details
[Re: Supercuda]
#1163467
01/28/12 12:41 AM
01/28/12 12:41 AM
wldtm
Dayton, Ohio
94/95 - the OP was talking about obd 1. mine was the same year.
I have helped with this exact swap, and actually made the harness for the swap. if you really want to keep the efi and the 727, it is very doable.
PM for details
[Re: wldtm]
#1163468
01/28/12 01:21 PM
01/28/12 01:21 PM
Supercuda
About to go away
About to go away
up yours
nothing like hands on experience.
[Re: wldtm]
#1163469
01/29/12 10:05 PM
01/29/12 10:05 PM
Posts: 10,585 Freeport IL USA
poorboy
Freeport IL USA
Sounds to me like you may have a market for such a wiring harness. There are a lot of people that would love to put EFI on older Mopars. If your harness would accomplish that, I think you could sell a bunch of them. Gene
[Re: poorboy]
#1163470
01/29/12 11:35 PM
01/29/12 11:35 PM
wldtm
Dayton, Ohio
Unfortunately not so. I have two cars done in running (both friends/family). I have advertised for about 6 months, and havent sold one. They are 275 for just the harness. I thought that was very reasonable.
Oh well...
PM for details
[Re: wldtm]
#1163472
01/30/12 01:49 PM
01/30/12 01:49 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
Oh well...
Justin, I have 2 projects that will need your harness's, but they keep getting put on the back burner and no money at this time to put into those projects, but soon I hope and we will be in touch. Ron....
