Steering Column Wiring? #1163279
01/23/12 12:33 PM
01/23/12 12:33 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
I have the steering column in the car now and I have not been able to figure out what this single yellow wire goes to. Im not seeing it on my wiring diagram??. Can anyone help on this??
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Steering Column Wiring? [Re: 19cuda73] #1163280
01/23/12 12:40 PM
01/23/12 12:40 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
4speed clutch safety switch?
1969 Dodge Charger 1969 Dodge Superbee
Re: Steering Column Wiring? [Re: 19cuda73] #1163281
01/23/12 12:46 PM
01/23/12 12:46 PM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
Ignition switch lamp; connects to the time delay relay harness under the dash.
Re: Steering Column Wiring? [Re: charger440sixpak] #1163282
01/23/12 01:51 PM
01/23/12 01:51 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Panel lamp dimmer switch Thanks yes I found it on the wiring diagram..
1972 Corvette
