Hotchkis Challenger
#1163156
01/23/12 02:38 AM
01/23/12 02:38 AM
Posts: 1,629 Gambrills, Md
mopork
Gambrills, Md
I love the Hotchkis Challenger it's exactly what I'm looking for in a good cornering street car. I have the TVS system on order now. So, I'm just going to copy it straight up but I need help locating everything they used to setup the Challenger. Does anyone know where I can get the following ? 6 piston StopTech calipers and 14" rotors 18" Forgeline wheels Coleman racing products 1.5:1 steering gear
Re: Hotchkis Challenger
[Re: mopork]
#1163157
01/23/12 04:11 AM
01/23/12 04:11 AM
Posts: 142 Petaluma, CA
JimDiesel
Petaluma, CA
Forgeline wheels This is the only vendor that I know of. I have never bought from them, they are active on pro-touring.com. Forgeline website is down, otherwise they most likely have a list of vendors. http://driverzinc.com/
68 Road Runner 67 Coronet
[Re: mopork]
#1163158
01/23/12 04:11 AM
01/23/12 04:11 AM
Posts: 4,442 Texas
Daty Rogers
World's Greatest Husband. I love you Robyn
Texas
[Re: Daty Rogers]
#1163162
01/23/12 08:42 PM
01/23/12 08:42 PM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
Call Hotchkis?
-Daty
Agreed, I have talked to their tech people alot in the past when I first built my dakota and found them to be very helpful. I really doubt they would have any problem sharing any of that info, especially with a customer that already has a full TVS system on order.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: mopork]
#1163163
01/23/12 09:02 PM
01/23/12 09:02 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Most of what is listed seemed pretty typical, the thing that caught my eye is the Coleman racing products 1.5:1 steering gear....
I'd expect a gear ratio between 16-1 & 20-1 not 1.5-1...
So I did some searching & it appears this isn't actually a steering gear per say but a multiplier... So when used with a stock 24-1 gear it will act like a 16-1 gear.... Interesting & probably a great idea for a Slalom event or a Autocross.. But I'm not sure it's a good choice for a dual purpose road/track car....
[Re: 1_WILD_RT]
#1163164
01/23/12 09:12 PM
01/23/12 09:12 PM
Posts: 96,661 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
I have 12 to 1 on my AMX. You DEFINITLY have to watch what you're doing on the street. Had an emergancy when some dip [Edited by Moparts - Family Friendly Site - Keep it clean] in a Blazer was half way across the center line around a curve. I didn't crash it, but got close to the ditch.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: 1_WILD_RT]
#1163169
01/24/12 03:16 AM
01/24/12 03:16 AM
Posts: 27,467 So Cal
autoxcuda
So Cal
Howe makes a piece called a "Steering quickener", this multiplies the steering wheel input to the steering box.
Same as the gear unit from Coleman Racing Products
Check out Speedway Motors or other big circle track supply places for good prices on those.
The tricky part to the quickner is the fabrication of installing it.
[Re: 1_WILD_RT]
#1163174
01/24/12 02:37 PM
01/24/12 02:37 PM
autoxcuda
So Cal
Autox
yes there is precious little space down there to install anything
It could be mounted under the dash... Your gonna be fabricating to mount it anyway, theres a good brace point under the dash, just gotta section the column... Ask Hotchkis for pictures of their setup..
I got picture that I took of it. I've posted them before.
The two U-joints will cost as much or more than the reduction box. Don't know why they are using two U-joints. ....
So this unit strictly attaches to the column? The units I saw online had a mounting pad to attach the housing to keep it from spinning...
That pad is attached to the column. There are at least two flat stocks that run down the sides of the column, a cross bar/pad?. It was tough to get in there and take pictures. A lot of stuff in the way. There's more going on in there than what my limited pictures are showing.
The pictures show it can be done. But the picture don't exactly show how to do it.
