Steering column Wire Harness #1163076
01/23/12 12:32 AM
01/23/12 12:32 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Installed my column the other day on the cuda and hooked up the wiring at the base of the column. Is there anything that holds up the wiring just to tie it up and out of the way?
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Steering column Wire Harness [Re: 19cuda73] #1163077
01/23/12 12:47 AM
01/23/12 12:47 AM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
It is supposed to wrap around the column once and then plug in . Same with the turn signal switch wires .
Re: Steering column Wire Harness [Re: 19cuda73] #1163078
01/23/12 11:03 PM
01/23/12 11:03 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Do you mean from where the wire exits the tube and the connection to the dash wiring? It just plugs in without any support. There is not a lot of extra wire that requires any support.
Craig
