2005 neon fuel rail #1163057
01/22/12 11:39 PM
01/22/12 11:39 PM
Portlandia
wimcle Offline OP
wimcle  Offline OP
Portlandia
In the chiltons guide it shows a test port on the drivers side end of the fuel rail, under a black cap.
On mine there isnt one, it has the same metal cap soldered on both ends. I found a pic of an fuel rail on ebay and it has a black cap on one end???
Is there somewhere different to test fuel pump pressure?
'00 cbr929rr -- '98 Ram SS/T -- '67 Dart Conv. --'05 Neon -- '09 Wrangler
Re: 2005 neon fuel rail [Re: wimcle] #1163058
01/22/12 11:45 PM
01/22/12 11:45 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
www.neons.org , specifically the Second Gen section.
Re: 2005 neon fuel rail [Re: wimcle] #1163059
01/22/12 11:50 PM
01/22/12 11:50 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
That year you have to put an inline tee into the rail inlet. There is no test port built in. Its spx #6539.
