Electric Fans users!!! On/off switch...... #1163024
01/22/12 10:19 PM
01/22/12 10:19 PM
alberta
Publicbottle Offline OP
alberta
Hey all!
just looking at different ways of wiring my electric fan setup that came with my afco radiator. I like the idea of and adjustable probe that mounts externally on the radiator. I see summit has a few to choose from. Otherwise to use a temp sending unit, i am looking at drilling a hole in either my intake or radiator, and im not too keen on doing either. So, just looking for feedback on the external adjustable style if anyone has or is using one.
Re: Electric Fans users!!! On/off switch...... [Re: Publicbottle] #1163025
01/22/12 11:16 PM
01/22/12 11:16 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
my shelby dakota uses electric fans, computer controlled. the fans died, and the replacement uses a radiator fin probe, to operate. it goes into a control box that allows me to set the high/low, and it works fine. the probe is up top, near the radiator inlet. a second wire runs to the a/c compressor to run it whenever the a/c is on, but on a non-a/c car, you could use this extra circuit for a manual over ride. i've put 15K miles since the conversion, and no issues.
Re: Electric Fans users!!! On/off switch...... [Re: Publicbottle] #1163026
01/23/12 01:44 AM
01/23/12 01:44 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have been using SPAL PWM fan controllers on my car and a few others I have done for a few years with no problems.
http://www.spal-usa.com/fans/automated/accessories/fanpwm.html
Re: Electric Fans users!!! On/off switch...... [Re: Azzkikrcuda] #1163027
01/23/12 02:02 AM
01/23/12 02:02 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I use a Spal controller also....workes perfect. (control 2 fans with it...and use the factory sending unit to trigger it in my case, and also use a trinary A/C switch to trigger it as well)
Re: Electric Fans users!!! On/off switch...... [Re: Publicbottle] #1163028
01/23/12 02:22 AM
01/23/12 02:22 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
I'm using this one from Summit:
http://www.summitracing.com/parts/HDA-3653/
I've had it in for two summers and have had no problems with it. It's adjustable and has a probe, like the one you're looking at. It just took a little playing around when I first installed it to dial it in so that it comes on when I want it to, and I haven't had to touch it since then. It's been very consistent, coming on at the same temperature (according to my temp gauge) every time. Even though this one has a built-in relay, I'm using a second relay for the power to the fan, figuring that the thermostat will last longer if I'm not running high amps through it.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: Electric Fans users!!! On/off switch...... [Re: Evil Monkey] #1163029
01/23/12 10:20 AM
01/23/12 10:20 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
what is the advantage of having it shut off?
Re: Electric Fans users!!! On/off switch...... [Re: Golden-Arm] #1163030
01/23/12 03:16 PM
01/23/12 03:16 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
My two electric fan (non-factory) cars have different setups. The daily driver Supra has a Flex-a-lite 220 puller with a DC Control FK 35 controller. Temp probe is near the bottom tank, but at the side away from the radiator outlet. Also bought the fan operation indicator light with the kit. Some say to put the probe at the rad inlet, but I saw no need to have the fans run every time the thermostat opened. The temp gauge sits rock steady once it reaches temperature, and the fans only run occasionally at speeds above 35 mph, except in hot weather. Been in there 8 years with no problems.
The RR has a Flex-a-lite 480 puller fan with their controller. The probe is right at the radiator inlet, per the instructions. Might move it, depending on how it behaves once it's driving. But the few times I've run the engine, they've worked as advertised.
Both controllers are digital control, they control the fan motors by digitally turning the power to the fans on and off to slowly ramp up the electrical load, rather than simply turning them on and spiking the current draw on the electrical system.
Re: Electric Fans users!!! On/off switch...... [Re: bonefish] #1163031
01/25/12 08:13 AM
01/25/12 08:13 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
No sense running a fan full time when you don't need to. Like any other electric motor, running an electric fan full time will mean it's going to burn out quicker, not to mention the extra load on your alternator, which will shorten it's life also.
Re: Electric Fans users!!! On/off switch...... [Re: Evil Monkey] #1163032
01/25/12 08:37 AM
01/25/12 08:37 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
plus, the benefit of an electric fan is that it's on when you need it and off when you don't. if you wire it up to run full time, then you might as well get rid of the electric and put on a mechanical fan.
**Photobucket sucks**
Re: Electric Fans users!!! On/off switch...... [Re: Publicbottle] #1163033
01/25/12 02:44 PM
01/25/12 02:44 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Hey all!
I use a similar unit as your picture that is manufactured by hayden. The first two I pulled off of the shelf were internally wired wrong but they have since corrected that. Check yours for correct operation prior to installation.
