can I use a stock 360 windage tray in my 408 stroker #1163020
01/22/12 10:09 PM
01/22/12 10:09 PM
littlestown pa
dustpan man Offline OP
littlestown pa
I'm not sure if I can use my windige tray in my stroker. Also I'm running the mopar 509 cam with indy magnum heads what kind of lifters should I get stock amc style or performance style lifters ?
Re: can I use a stock 360 windage tray in my 408 stroker [Re: dustpan man] #1163021
01/22/12 10:59 PM
01/22/12 10:59 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
You might be able to get the tray to work, but probably not. I know I couldn't get my 340 tray to clear the rod bolts with a 4" stroker crank. Not a lot of value performance-wise anyway.
Stock pan is lacking in both baffling and capacity. I'd recommend an upgrade. The Kevko pan is a good budget friendly option. It's good for an extra quart or two, offers good oil control, and doesn't sacrifice ground clearance significantly.
Not sure what the best lifter option is with the Magnum style head.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: can I use a stock 360 windage tray in my 408 stroker [Re: 471Magnum] #1163022
01/23/12 01:01 AM
01/23/12 01:01 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I used the stock windage tray in my '77 360 based 408 build. I run a stock pan and melling regular volume pump with no pressure problems. This is with a 557 solid cam that likes 4-6k blasts pretty regularly. I don't know if the tray helps or not, Im guessing there might be a little power in better oil control in a more serious build.
Re: can I use a stock 360 windage tray in my 408 stroker [Re: dustpan man] #1163023
01/23/12 10:33 AM
01/23/12 10:33 AM
If your 4 special bolts come w the thick washers use them to space the bolts out further tho I prefer to get as much thread engagement as possible esp on a killer build then use small spacers/longer small bolts to space the tray out further from the 4 main bolts. Mock it up & see where you're at EDIT yes open the louvers up, they're too tight as is
