1999 Caravan door lock circuit breaker? #1162630
01/22/12 03:54 PM
01/22/12 03:54 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Anyone know where this circuit breaker is and how to replace it?
Re: 1999 Caravan door lock circuit breaker? [Re: 451Mopar] #1162631
01/22/12 07:28 PM
01/22/12 07:28 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
whats wrong with it? only up or only down or no work at all?...some of these vans if u disconnect the battery terminal it reboots the bcm ...
Re: 1999 Caravan door lock circuit breaker? [Re: 451Mopar] #1162632
01/22/12 10:15 PM
01/22/12 10:15 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
The wifegod has a '98 Grand Voyager.
In that model, the door locks are protected by a 40 amp FUSE in the fuse/breaker panel under the hood, just outboard of the battery.
The lid has a roadmap, which (in her '98) shows the fuse to be next to the top in the column of 40 amp fuses.
As has already been said, the body computer controls the locks, and knows better than all of us mere mortals. A reset might be in order (by leaving the battery disconnected for a while).
Down to just a blue car now.
Re: 1999 Caravan door lock circuit breaker? [Re: 68HemiB] #1162633
01/22/12 10:49 PM
01/22/12 10:49 PM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
Iwas told if you have a bad solenoid on one of the doors usually the one that wont lock or unlock is what the problem is . i have a 03 t/c ireplaced both of the sliding door solenoids and it still likes to keep locking . it has burnt the new ones up till they stay in the locked postion i replaced both of them again and left them unplugged so i could open the doors . i just manually lock them a chrysler tech said to hold the door lock switch up for 10 seconds and it resets them for awhile i always wonder if the wiring tracks in the slides were causing the problem ,
