426 Hemi Spark Plugs - OK without washer? #1162568
01/22/12 02:30 PM
01/22/12 02:30 PM
CrazyD Offline OP
CrazyD  Offline OP
No piston clearance issues with removing the washer on spark plugs (Champion N11YC 13/16")? Know some run without the washer, but want to confirm will not have clearance issues if plug runs down 2-3 more threads without washer.
Stock iron head crate Hemi. Have a leaky tube, checked for distortion, heard a plug w/o washer will seat better, with more surface area.
Thanks!
Re: 426 Hemi Spark Plugs - OK without washer? [Re: CrazyD] #1162569
01/22/12 02:39 PM
01/22/12 02:39 PM
California
mickm Offline
mickm  Offline
California
people swear both ways by it, use them or don't use them.
if you think that will help the issue, then try without them. do all 8 of course
Re: 426 Hemi Spark Plugs - OK without washer? [Re: CrazyD] #1162570
01/22/12 02:51 PM
01/22/12 02:51 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The spark plug TUBE is your washer, no washers on the plug, using washers distorts the tube seat, inviting leaks
Re: 426 Hemi Spark Plugs - OK without washer? [Re: CrazyD] #1162571
01/22/12 03:17 PM
01/22/12 03:17 PM
All the factory motors including the high compression race motors came with the washers installed, just like they disegn them for Sounds like you need some Mr Gasket or Milidon spark plug tube seals
Re: 426 Hemi Spark Plugs - OK without washer? [Re: Cab_Burge] #1162572
01/22/12 04:07 PM
01/22/12 04:07 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
FSM says to remove washers...just for comparison. Tim
Re: 426 Hemi Spark Plugs - OK without washer? [Re: astjp2] #1162573
01/22/12 04:27 PM
01/22/12 04:27 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I concur,.....line 5
Re: 426 Hemi Spark Plugs - OK without washer? [Re: DAYCLONA] #1162574
01/22/12 06:37 PM
01/22/12 06:37 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Re: 426 Hemi Spark Plugs - OK without washer? [Re: astjp2] #1162575
01/22/12 08:17 PM
01/22/12 08:17 PM
I have three Mopar original FSM 1969,70 and 71 Plymouths and reproduction 1969 Dodge FSM, none of them say to remove the stock spark plug washers I have seen the bottom of the stock tubes pull out by people who removed the stock washers
