Re: Installing hemi hood scoop on '69 Barracuda.
[Re: VITC_GTX]
#1162419
01/22/12 01:50 AM
01/22/12 01:50 AM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
I was thinking of cutting the hole the same shape as the scoop but 1 inch smaller. Thoughts?
R U doing this for fresh air for the motor or engine cooling ?
[Re: SSAAHemiFan]
#1162420
01/22/12 01:55 AM
01/22/12 01:55 AM
Posts: 4,929 Tri-Cities, Washington
VITC_GTX
Looks best with the cutout in the same shape as the scoop.
Depending on how far back you place it you may be also be cutting into the rear brace. I had to on my 69 because of the crossram. I them reboxed it as this portion ties into the hinge area.
I also made a very small notch on the rear flange to help the scoop bend and then filled it.
Scoops are made for the flatter 68 hoods as you know 69's are shaped a bit different.
Good information, thanks.
I'll see if I can mount it far enough forward to avoid the rear brace.
[Re: dOrk !]
#1162421
01/22/12 01:56 AM
01/22/12 01:56 AM
VITC_GTX
Neither...looks
[Re: dOrk !]
#1162423
01/22/12 02:56 AM
01/22/12 02:56 AM
VITC_GTX
I would cut it out a tad bigger than the air-cleaner ... that scoop will sure help performance.
Maybe I'll build a plate to seal the hood to the air cleaner.
[Re: VITC_GTX]
#1162424
01/22/12 06:10 AM
01/22/12 06:10 AM
Posts: 1,018 Missouri
MOBodyman
Missouri
Something like this? Dallas
2012 Rallye Redline Challenger, 1st new car! 2010 Ram 1500 4wd HEMI-hauler 2014 Dodge Dart-gas saver 4 projects and a bunch of parts cars, losing interest since buying the Challenger lol 1969 Dodge Coronet 500-'gonna fix 'er up someday!'
[Re: MOBodyman]
#1162426
01/22/12 06:14 AM
01/22/12 06:14 AM
MOBodyman
Missouri
Last one. Too bad you aren't closer. I would have sold you this one if you liked it. Dallas
[Re: MOBodyman]
#1162429
01/22/12 10:34 PM
01/22/12 10:34 PM
VITC_GTX
Can't you hand deliver
Hopefully it won't take me too long to cut the hole and install.
Thanks to all for the help and ideas.
