BB Cast crank balancers #116240
09/06/08 09:09 PM
09/06/08 09:09 PM
MB,CAN
PC-CHARGER Offline OP
MB,CAN
Is the 440 cast crank harmonic balancer the same as the one used on a 400 cast crank engine?
Re: BB Cast crank balancers [Re: PC-CHARGER] #116241
09/06/08 09:21 PM
09/06/08 09:21 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Nope. The 440 one is considerably bigger.
I have one of each here; if I can find 'em I'll post a pic.
Re: BB Cast crank balancers [Re: vdriver] #116242
09/06/08 09:30 PM
09/06/08 09:30 PM
MB,CAN
MB,CAN
Thanks for the reply and I'd appreciate a picture of the 400 balancer if you have one. I have a 440 cast balancer and it has "440 Cast Crank" cast into it so that's why I asked.
Re: BB Cast crank balancers [Re: PC-CHARGER] #116243
09/07/08 01:22 AM
09/07/08 01:22 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Here ya go:
Re: BB Cast crank balancers [Re: vdriver] #116244
09/07/08 01:23 AM
09/07/08 01:23 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
One more:
Re: BB Cast crank balancers [Re: vdriver] #116245
09/07/08 10:31 AM
09/07/08 10:31 AM
MB,CAN
MB,CAN
Thank you. Obviously the 400 balancer is a fair bit thinner than the 440 one I have.
Thanks again
Re: BB Cast crank balancers [Re: PC-CHARGER] #116246
09/08/08 11:00 AM
09/08/08 11:00 AM
dogdays Offline
dogdays  Offline
However, the cast crank 383/400 and the cast crank 440 have EXACTLY the same amount of unbalance. The dampers will interchange functionally. I don't understand why there are different dampers.
R.
