Re: Hemi afb accelerator pump problem
[Re: hemi67]
#1162285
01/22/12 11:30 AM
01/22/12 11:30 AM
RapidRobert
idle it for a minute to fill the bowl then take off the metering rods/carb top and take off the A/P plunger & push it down in the bore & see if you get a good squirt as the top does not need to be installed to check AP function. You can use a screwdriver around the inside perimeter of the leather cup between the cup and the spring to expand it a bit and there's several AP assemblies & they may have used the wrong one. I oil the leather to make it supple & conform to the bore better and take a better initial set. Not sure which is better leather or the neoprene type (ScottSmith Harms will know) but I'd get a new plunger & likely one of the eddy performer ones will fit and they are avail seperately
[Re: hemi67]
#1162289
01/22/12 02:35 PM
01/22/12 02:35 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Thanks for your help, but I think I found the problem. I put the top of the front carb on the rear carb and now I have a pump shot. Looks like the hole in the top from the rear carb where the acc pump rides in is worn causing the pump to move sideways while pumping up and down. to double check this, I installed the top from the rear carb on the front carb, and the problem followed the top, no pump shot on the front carb, which worked fine before. Does anybody make a bushing for the pump hole in the carb top, or an oversize acc pump, or just change the carb top on the rear carb with one in better condition?
thanks
Did you try to swap the accel pump from the front carb to the rear carb without swapping the tops just to confirm it's the top and not the pump or anything else.
I think you'll have to make a bushing yourself , it wouldn't be that hard to do or have done .
