oil pan #1162130
01/21/12 06:18 PM
01/21/12 06:18 PM
indiana
moparbrown14 Offline OP
indiana
im building a 408 from a 75 360 block. Are the small block oil pans different. will a small block oil pan fit. 318-340
Re: oil pan [Re: moparbrown14] #1162131
01/21/12 06:31 PM
01/21/12 06:31 PM
Locomotion Offline
Locomotion  Offline
You'll need a 360 oil pan to fit the 360 block. 318 and 340's have the same front and rear seals while the 360 has a different style and smaller rear seal.
Re: oil pan [Re: Locomotion] #1162132
01/21/12 06:39 PM
01/21/12 06:39 PM
indiana
indiana
im going to order an aftermarket one that holds about 7-8 quarts. does it have to be a certain year
