Re: 727 issue?
[Re: xpsyclonex2002]
#1162050
01/21/12 06:15 PM
01/21/12 06:15 PM
Posts: 25,836 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Can you turn the motor over manually by turning the crank or converter? Did the converter bolt up to the flexplate with no pullup?
The Gen III Hemi crank extends a little further from the block than previous V8's, this could shove the converter into the trans too far and cause the binding...only way to know for sure is to unbolt the converter from the flexplate and see if it will turn.
Re: 727 issue?
[Re: mrrandyj]
#1162052
01/21/12 09:33 PM
01/21/12 09:33 PM
Posts: 71 Memphis, MO
xpsyclonex2002
Memphis, MO
Was the new TCI torque converter that you bought made for your 1966 transmission, or for the 67-up transmissions? The input shaft was changed in 1967, and almost all aftermarket torque converters are made for the 67 and newer transmissions.
Yes, it was for the 66 model 727.
Re: 727 issue?
[Re: John_Kunkel]
#1162053
01/21/12 09:36 PM
01/21/12 09:36 PM
xpsyclonex2002
Memphis, MO
I knew about the projection. I bought a flex plate from Mancini that is made for this swap and adjust for this offset. I am nor sure what you mean by "pull up" though?
Re: 727 issue?
#1162055
01/21/12 09:55 PM
01/21/12 09:55 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
What he's refering to is..When the engine/trans were mated there should be some amount of freeplay between the torque converter and flexplate...The torque converter should have slid back into the trans far enough that you had to "pull up" the convertor to meet the flexplate....That's why he's asking you to unbolt the unit from the flexplate and give the convertor a spin to make sure it spins freely between the plate and trans...
